Add Dynatrace nodes to cluster using API and DevOps
We’re planning to automate adding the Dynatrace nodes to cluster in DevOps using the rest APIs. is there any possibility to fetch the seed-auth token and installer package using the Rest APIs?
You can use Service Provider API token as seed token.
