The apache process is activation for deep monitoring is unsuccessful with error permission issue for the process. the process is running as a container on kubernetes cluster node, Other process running on the same vm are monitoring without any issues.
There may be an issue with the startup times for the containers depending on deployment strategy?
There is a startup dependency between the container in which OneAgent is deployed and application containers to be instrumented (i.e., which have deep process monitoring enabled). The OneAgent container must be started and the oneagenthelper process must be running prior to the application container being launched so that the application can be properly instrumented.
I have the same problem. Processes were restarted however the oneagent communicates with AG via port 443. COuld this be the problem? Becuase I have found lots of errors You mentioned but also found messages saying the communication works via 443.
@Peter_Lepsis Can you describe your situation more?
OneAgents have a list of communication endpoints (configuration file - from installation / k8s deployment, get that from the Operator). It will be updated as soon as the OA connects.
Network zones may have a role here if you use them, and it depends on how zones are configured (fallback zones).
Yes, I know that. As I mentioned in the Oneagent pod’s ruxitagent log file I found these entrie:
2026-03-29 00:26:57.632 UTC [0038a353] info [comm ] URL https://*********************:9999/communication not working (Connection timed out after 2000 milliseconds) (occurred 3 times in the last 1h 0m 0s)
2026-03-29 00:26:59.633 UTC [0038a353] info [comm ] URL https://10.178.109.7:9999/communication not working (Connection timed out after 2000 milliseconds) (occurred 3 times in the last 1h 0m 0s)
2026-03-29 00:27:01.634 UTC [0038a353] info [comm ] URL https://10.43.247.61:443/communication not working (Connection timed out after 2000 milliseconds) (occurred 3 times in the last 1h 0m 0s)
2026-03-29 00:27:01.669 UTC [0038a353] info [comm ] URL https://uniqak8sdt-activegate.dynatrace-operator:443/communication not working (Could not resolve host: uniqak8sdt-activegate.dynatrace-operator) (occurred 3 times in the last 1h 0m 0s)
2026-03-29 00:27:03.670 UTC [0038a353] info [comm ] URL https://*********************:9999/communication not working (Connection timed out after 2000 milliseconds) (occurred 3 times in the last 1h 0m 0s)
2026-03-29 00:27:03.886 UTC [0038a572] warning [native] updateMetrics took longer than expected: 3715 ms. Check the profiler output.
2026-03-29 00:27:05.671 UTC [0038a353] info [comm ] URL https://10.178.109.5:9999/communication not working (Connection timed out after 2000 milliseconds) (occurred 3 times in the last 1h 0m 0s)
2026-03-29 00:27:06.616 UTC [0038a353] info [comm ] Connected to https://*********************:443/communication
from this entry can be seen that the pod can communicate only on the 443 port.
@Peter_Lepsis, without knowing your environment, it’s hard to give any suggestions. From the pod (assuming it’s from K8s), it’s not possible to connect to these endpoints. There can be multiple reasons, such as firewalls, Kubernetes network policies … You must check the connectivity from the pod to your desired ActiveGate.
