Activegate Comand Panel to Modify Group Assignment
I  cannot see the command panel to modify an Activegate group after installation. Does this feature require to be enabled on an environment?
@wolfgang_beer
@echwallah I am not the right person for that question, sorry.
Sorry @wolfgang_beer That was by mistake. It was a general Question to the community.
I cannot see this feature to modify an Activegate Group After Installation.
So probably the documentation is not accurate or something am not seeing or it has to be enabled by DT
You can change it after installation. Details are here.
Best regards
I just figured this out. Thanks @AntonPineiro but the issue was not understanding the documentation. I was just not finding where the command panel is.
I just realized you just need to select the checkbox of the Activegate. My mistake was I though it would appear once you just click on the activate which one might misinterpret from documentation to be selecting the Activegate(Expanding it). Selecting actually was ticking on the checkbox
