Hello there, i have created an Activegate extension using SDK version 1.275. when executing the `verify_plugin` command, no issue is reported and the `simulate_plugin` does not give errors either. issue is when I’m trying to upload the extension, I’m getting following error: `UI keyMetrics section: key refers to a non-existent timeseries (sendgrid.delivered)`
Below sample of my `plugin.json` file built using Extension JSON explained | Dynatrace Docs:
"ui": {
"keymetrics": [
"key": "sendgrid.delivered",
"aggregation": "max",
"mergeaggregation": "sum",
"displayname": "Delivered emails"
"keycharts": [
"group": "API status",
"title": "State",
"series": [
"key": "sendgrid.api.connection",
"displayname": "SendGrid API Connection Status",
"seriestype": "bar",
"statecolors": ["#ff3333", "#ffd633", "#00b33c"],
"statechart": true
"group": "SendGrid",
"title": "Delivered emails",
"series": [
"displayname": "Delivered emails",
"seriestype": "line",
"statecolors": ["#ff3333"],
"statechart": true
"charts": [
"series": [
"color": "#74cff7",
"metricexplanation": "The number of emails SendGrid was able to confirm were actually delivered to a recipient."
"metrics": [
{ "statetimeseries": {
"states": ["DOWNTIME", "MAINTENANCE", "WORKING"],
"displayname": "Sendgrid API Connection"
"entity": "CUSTOM_DEVICE"
"timeseries": {
"unit": "Count",
"aggregation": "SUM"
Thanks for your help.
Cedric
