Hi!
We are deploying ActiveGates in AWS, and they get the less meaningful ip-1123-123-123-123- names. Is it possible to somehow control their naming, or where do they get their name from?
I tried altering the server’s hostname before installing it, but it still picks the private DNS name.
Any suggestions?
Hi @tarjei_utnes1
Could you please check this post?
Solved: Rename dynakube-activegate-0 - Dynatrace Community
I hope it helps.
Best regards,
János
Hi!
This is not kubernetes deployments but deployments on VMs. But thank you for the suggestion!
When the ActiveGate starts it determines its name by doing a reverse lookup on the primary IP. To change the name the ActiveGate sees, update /etc/hosts locally or if you have a route53 domain configured, add an A record for the host.
For example:
ubuntu@ip-10-0-4-119:~$ getent hosts 10.0.4.119<br>10.0.4.119 ip-10-0-4-119.ec2.internal<br><br>ubuntu@ip-10-0-4-119:~$ echo "10.0.4.119 dynatrace-ag" | sudo tee -a /etc/hosts<br>10.0.4.119 dynatrace-ag<br><br>ubuntu@ip-10-0-4-119:~$ getent hosts 10.0.4.119<br>10.0.4.119 dynatrace-ag
This results in the correct name after AG restart.
/Lars J.
