Hi Folks,
Previously I saw a community post about this topic but I have not found it.
Can anybody share it again?
Best regards,
Mizső
Hi Folks,
Best regards,
Mizső
You can change ActiveGate names to some extent. The names are generated, but they always follow a certain pattern: <DynaKube.metadata.name>-activegate-#.
The name can be set in the metadata of the DynaKube custom resource:
apiVersion: dynatrace.com/v1beta1<br>kind: DynaKube<br>metadata:<br> name: my-name<br> namespace: dynatrace<br>...
The first ActiveGate pod will then be named like this: my-name-activegate-0
But be aware, that your secrets (API Token and PaaS Token), should also be named like that, or you need to pass the actual name into the cr.yaml tokens field.
