Hi guys, I need to change my ActiveGate port number, that is 9999. Is it possible to change the port number as well as is this changed in UI as we can change for the cluster node in the UI? Please help…
the change is in the file /var/lib/dynatrace/gateway/config/custom.properties. You must add in the com.compuware.apm.webserver session, for example for the port 3050:
[com.compuware.apm.webserver]
port-ssl =3050
Then restart activegate services.
Thanks Miguel does the changed port will listen to the dynatrace cluster .
can we also change the cluster node ports and connect it to the changed port of activegate.
The change is in the activegate, I don’t recommend change the ports of the dynatrace cluster.
