Hello all,
So when we do Dynatrace Demo, our customer prospect asking about these question:
- ActiveGate (Environment/Cluster) communicate to Managed Cluster by default through port 443 right? Is it possible to change the communication to for example 1077?
- Also to accessing managed cluster we could directly use it’s IP right? Is it possible to custom the port for accessing the cluster management console? For example 192.168.101:4443.
Thank you in advance.
Hi @agylpradipta
Dynatrace ActiveGate allows you to specify custom communication ports. This means that you can configure ActiveGate to listen for traffic from OneAgent on ports other than the default ports. To do this, adjust the settings in the custom.properties and launcheruserconfig.conf files located in the ActiveGate configuration directory. If you are changing ports in the Dynatrace Managed cluster itself, it is best that you contact support. I don’t know if this is even possible.
Radek
