Add a variable to the “from:" and "to:” section of a DQL query
Is it possible to add a variable to the “from:" and  "to:” section of a DQL query that is fetching logs?
Background: I have a dashboard that surfaces info from logs from a specific time of the day each morning. I want to be able to select a value in a dashboard variable that represents today, yesterday, 2 days ago, 3 days ago, etc. and have the dashboard show data for that specific time period of the chosen day.
The following DQL examples work correctly. I’d like to have a dashboard variable that changes the day being specified in the To and From sections.
Today:
  • fetch logs, from: bin(now(), 1d)+ 5h + 50m, to: bin(now(), 1d) + 6h + 30m
Yesterday:
  • fetch logs, from: bin(now()-1d, 1d)+ 5h + 50m, to: bin(now()-1d, 1d) + 6h + 30m
Two Days Ago:
  • fetch logs, from: bin(now()-2d, 1d)+ 5h + 50m, to: bin(now()-2d, 1d) + 6h + 30m
Is this possible? What would the DQL look like?
@cwinkler109 you can accomplish this using a list variable, for example:
Along with the following query:
fetch logs,
 from: duration(toLong(concat("-",$daysAgo)), unit:"d")@d+5h+50m,
 to: duration(toLong(concat("-",$daysAgo)), unit:"d")@d+6h+30m
| summarize min(timestamp), max(timestamp)
As a side note, just so I understand it, are you looking to create a dashboard that shows logs for a given day between 5:50am and 6:30am local time? If so, you may get some inconsistent responses using bin() format based on the timezone.
I’ve attached a copy of an example dashboard using this functionality and showing some differences between bin() and @d.
Timeframe Variable Test.json.zip (1.96 KB)
Perfect. AustinSable, you are a DQL hero, and saved my dashboard. Thank you!!!
Glad I could help!
