Is it possible to filter the time with a time range only, e.g. from 5:30am yesterday to 5:30am today?
Hi Stefan,
this should be the query
fetch logs, from: bin(now()-1d, 1d) + 17h + 30m, to: bin(now(), 1d) + 17h + 30m
basically, you make use of the from an to parameters.
- with now()-1d, you specify the timeframe exactly 24h ago
- then with bin(now()-1d, 1d) you round it to the start at the day, so at midnight
- then you add the time of the day with + 17h + 30m
Best,Sini
Also,
If your timezone is not in UTC then you might have to subtract/add that from the timeframe as Sini mentioned above.
My timezone is UTC+5:30 so I had to
from: bin(now()-1d, 1d) -5h -30m, to: bin(now(), 1d) -5h - 30m
do this to get the data of previous day.
Thanks @sinisa_zubic this saved lot of effort for me :smiley:.
Maheedhar.
