Add loop task to enable or disable host monitoring
Hi team,
I want to use loop task for a list of hosts to enable or disable monitoring in Dynatrace. I would like to have multiple hosts to be executed with single workflow for http_request.
"externalId": "string",
"schemaId": "builtin:host.monitoring",
"schemaVersion":"1.4",
"scope": "HOST-7AA30C2D50D93E12",
"value": {
"enabled": false
Hi @Smalhotra89
Yes this is possible with the loop task. Before you start you need to generate an “Access Token” with the scopes “Read settings” and “Write settings”.
Then you can start creating the workflow. First you need to fetch all settings objects for the list of hosts you want to disable or enable with a http request task. The list of hosts is put in the URL and is comma separated. In the header section you add the Autorization details, please have a look at following screenshot
in the subsequent http request task you need to configure the loop task like this
The input for the tasks should be that
For this approach you have to create the token and manage it yourself.
But you could also do the same thing with a javascript task with custom javascript code, the benefit there would be that you don’t need to create a token for changing the settings. Since the used sdks underneath managed this for you.
this is the snippet for the javascript task
// optional import of sdk modules
import { execution } from '@dynatrace-sdk/automation-utils';
import { actionExecution } from "@dynatrace-sdk/automation-utils";
import { SettingsObject, settingsObjectsClient } from "@dynatrace-sdk/client-classic-environment-v2";
export default async function ({ execution_id, action_execution_id }) {
  // your code goes here
  // e.g. get the current execution
  const ex = await execution(execution_id);
  const actionEx = await actionExecution(action_execution_id);
  const scopes = actionEx.loopItem["host"];
  //console.log(scopes);
  const settingsObjects = await settingsObjectsClient.getSettingsObjects({
      schemaIds: "builtin:host.monitoring",
      scopes,
      fields: "objectId,value,summary,searchSummary,created,modifid,createdBy,modifiedBy,author,updateToken,scope,modificationInfo,schemaId,schemaVersion,externalId"
  //console.log(settingsObjects);
  if (settingsObjects.items.length > 0){
    const settingsObject = (settingsObjects.items[0]);
    const settingsObjectResponse = await settingsObjectsClient.putSettingsObjectByObjectId({
        objectId: settingsObject.objectId,
        body: {
          updateToken: settingsObject.updateToken,
          value: {
            "enabled": false
    return { settingsObjectResponse };
Best,
Sini
Thanks Sini, javascript task works well.
I was unable to use the http request with loop task as it was unable to read allobjects.json.item in loop. I am not sure if I did something wrong but the first task to get all objects task ran through fine.
How do I iterate through all values from a fetch query using javascript?
here is the loop item
nvm. figured it out
this worked for me and disabled monitoring on all hosts
Thank You, I made it work for all tagged hosts.
Hi  @vs185250 ,@Smalhotra89
I hope you guys are doing well.
I have replicated the above use case in my environment and it is not getting executed and requesting your help here.
Do I have to pass any bearer token ?
Hi @DineshP,
In this case you have to use API token instead Bearer Token.
The APIs using in this workflow requeries API token.
Hope it helps.
Elena.
Hi @erh_inetum ,
Thanks for the assistance, It would be great if you can help with some steps to proceed further to achieve the same.
Regards
DP
You have to use this header:
headers: {
‘Accept’: ‘application/json; charset=utf-8’,
‘Authorization’: ‘Api-Token dt0c01.XXXXXXXXXXXXXXXXX’
like in this screenshot
sent by @sinisa_zubic in the first reply of this post.
Hope it helps.
Elena.
I have the same ask, can someone upload a workflow that uses javascript or api method to enable or disable hosts that belong to a certain host group?
Batch file for now:
@echo off
setlocal ENABLEDELAYEDEXPANSION
REM ==== Config ====
set DT_ENV_URL=https://{environmentid}.live.dynatrace.com
set DT_API_TOKEN=dt0c01.YOURLONGA$$TOKENNAME
if “%DT_API_TOKEN%”==“” (
echo ERROR: Please set DT_API_TOKEN environment variable.
exit /b 1
set ENDPOINT=%DT_ENV_URL%/api/v2/settings/objects
REM ==== Host list ====
REM ++++Exported List from Dynatrace Infrastructure and Operations App++++
set HOSTS= ^
HOST-xxxaaa ^
HOST-xxxfffff ^
HOST-xxxddd ^
HOST-xxx
for %%H in (%HOSTS%) do (    echo Posting for %%H …    set PAYLOAD=[{““schemaId””:““builtin:host.monitoring””,““schemaVersion””:““1.4"”,”“scope”“:”“%%H”“,”“value”“:{”“enabled”":false}}]    curl -s -X POST ^        -H “Accept: application/json; charset=utf-8” ^        -H “Content-Type: application/json; charset=utf-8” ^        -H “Authorization: Api-Token %DT_API_TOKEN%” ^        -d “!PAYLOAD!” ^        “%ENDPOINT%”    echo.)endlocal
