Rather than interacting with the API via HTTP inside your workflow, you can actually make use of the Typescript SDKs to interact with things like settings more directly. In your case, I would think that the settingsObjectsClient should do the trick.
Tried similar things for trying setting the host mode via an AppFunction to test it before I add it to my workflow, but is not working despite I am giving it the right scope and more:
import { settingsObjectsClient } from “@dynatrace-sdk/client-classic-environment-v2”;
export default async function () : Promise<{ statusCode: number; message: string }>{ const hostId = “HOST-F6DC785465402DD8”; // Replace with your actual host ID try { const response = await settingsObjectsClient.postSettingsObjects({ body: [ { schemaId: “builtin:host.monitoring”, scope: hostId, value: { monitoringEnabled: false, }, }, ], }); return { statusCode: 200, message: “{hostId} - Monitoring state updated successfully.” };
} catch (error: unknown) { let errorDetails = “”; if (error instanceof Error) { errorDetails = `Error name: ${error.name}\n` + `Error message: ${error.message}\n` + (error.stack ? `Stack trace: ${error.stack}` : “No stack trace available.”); } else { errorDetails = `Unknown error object: ${JSON.stringify(error, null, 2)}`; } return { statusCode: 500, message: `${hostId} - Failed to update monitoring state.\nDebug info:\n${errorDetails}`, }; }}I am using platform token which has even more than it needs:Scopes: app-settings:objects:read, app-settings:objects:write, settings:objects:read, settings:objects:write, settings:schemas:read, app-engine:functions:run, app-engine:apps:runBut I get this error that this SDK call does not have the settings:objects:write
{"statusCode":500,"message":"HOST-F6DC785465402DD8 - Failed to update monitoring state.\nDebug info:\nError name: 403\nError message: OAuth token is missing required scope. Use one of: [settings:objects:write]\nStack trace: 403: OAuth token is missing required scope. Use one of: [settings:objects:write]\n at se.postSettingsObjects (<a target="_blank" rel="noopener">file:///invoker.js:5:19821)\n</a> at eventLoopTick (ext:core/01_core.js:177:7)\n at async Ds (<a target="_blank" rel="noopener">file:///invoker.js:5:47784</a>)"}
