I am looking into a way to attach a MDA (Multi-dimensional analysis) as a chart to specific Dashboard. After browsing across Dynatrace community there are 2 really interesting articles which stated that such action is possible:
My aim is to monitor the slowest query executed towards the DB. A custom metric can be created which will allow to monitor the queries and their count based on the custom created metric.
If you are interested in response time of a particular DB query, you can mark it as key request and then pin that to dashboard. It’s not straightforward, but it works.
Calculated metrics can be only measured at non-database services and you can only calculate total time spent in DBs or number of calls per request.
The slowest DB query from a service can be very volatile and highly dependent on the service request. What is your use case? (your first link is publicly accessible)
I am looking into a way to monitor the slowest running queries and their number, the largest occurances of the same queries. They will be part of a Performance Dashboard which will be used during Delivery, and Early Live Support of the application.
