My JSON file for the dashboard wouldn’t upload—it just kept loading without showing any error. So I’m trying it this way instead.
{"version":21,"variables":[{"version":2,"key":"cost","type":"text","visible":false,"editable":true,"defaultValue":"0.00234619141"},{"version":2,"key":"version","type":"csv","visible":false,"input":"2.0.0","multiple":false},{"version":2,"key":"costAlert","type":"text","visible":true,"editable":true,"defaultValue":"100"},{"version":2,"key":"decimalPlace","type":"csv","visible":true,"editable":true,"input":"0,1,2,3,4,5","multiple":false,"defaultValue":"5"},{"version":2,"key":"costAvgExecutionAlert","type":"text","visible":true,"editable":true,"defaultValue":"5"},{"version":2,"key":"limit","type":"text","visible":true,"editable":true,"defaultValue":"100"},{"version":2,"key":"DataType","type":"query","visible":true,"editable":true,"input":"fetch dt.system.events\n| filter event.kind == \"BILLING_USAGE_EVENT\" and matchesPhrase(event.type, \"Query\")\n| fields event.type\n| dedup event.type","multiple":true,"defaultValue":["3420b2ac-f1cf-4b24-b62d-61ba1ba8ed05*"]},{"version":2,"key":"user","type":"query","visible":true,"editable":true,"input":"fetch dt.system.events\n| filter event.kind == \"BILLING_USAGE_EVENT\" and matchesPhrase(event.type, \"Query\")\nAND isNotNull(user.email)\nAND in(event.type,$DataType)\n| fields user.email\n| dedup user.email","multiple":true,"defaultValue":["3420b2ac-f1cf-4b24-b62d-61ba1ba8ed05*"]},{"version":2,"key":"tenant","type":"query","visible":false,"editable":true,"input":"fetch dt.system.events \n| fields dt.system.environment \n| limit 1\n","multiple":false}],"tiles":{"34":{"title":"Query Cost Per Day","type":"data","query":"fetch dt.system.events\n| filter event.kind == \"BILLING_USAGE_EVENT\" and matchesPhrase(event.type, \"Query\")\nAND isNotNull(user.email)\nAND in(event.type,$DataType)\nand in(user.email,$user)\n| fields query_start, event.type, query_id, user.email, billed_bytes, timestamp\n| fieldsAdd query_cost = billed_bytes/1024/1024/1024*toDouble($cost)\n| makeTimeseries query_cost_sum = sum(query_cost), bins:1\n| fieldsAdd temp = if(isNull(query_cost_sum[]), toDouble(0), else:query_cost_sum[])\n| fieldsAdd `Cost` = arrayCumulativeSum(temp)\n| fieldsRemove temp","visualization":"barChart","visualizationSettings":{"dataMapping":{"displayedFields":["query_cost_sum","Cost"]},"chartSettings":{"truncationMode":"middle","legend":{"hidden":true},"xAxisLabel":"timeframe","xAxisScaling":"analyzedTimeframe","valueRepresentation":"relative","seriesOverrides":[{"seriesId":["Cost"],"override":{"geometry":"line"}}],"fieldMapping":{"leftAxisValues":["query_cost_sum","Cost"],"timestamp":"timeframe"}},"unitsOverrides":[{"identifier":"query_cost_sum","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759851623134},{"identifier":"Cost","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759851728698}]},"querySettings":{"maxResultRecords":1000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":100,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"davisVisualization":{"isAvailable":true}}},"36":{"title":"DQL Cost by Data Type Daily","type":"data","query":"fetch dt.system.events\n| filter event.kind == \"BILLING_USAGE_EVENT\" and matchesPhrase(event.type, \"Query\")\nAND isNotNull(user.email)\nAND in(event.type,$DataType)\nand in(user.email,$user)\n| fields query_start, event.type, query_id, user.email, billed_bytes, timestamp\n| makeTimeseries query_cost_sum = sum(billed_bytes/1024/1024/1024*toDouble($cost)), by:{event.type}, bins:1\n| fieldsAdd temp = if(isNull(query_cost_sum[]), toDouble(0), else:query_cost_sum[])\n| fieldsAdd `Cost` = arrayCumulativeSum(temp)\n| fieldsRemove temp","visualization":"lineChart","visualizationSettings":{"chartSettings":{"truncationMode":"middle","legend":{"hidden":true},"xAxisLabel":"timeframe","xAxisScaling":"analyzedTimeframe","valueRepresentation":"relative","seriesOverrides":[{"seriesId":["Events - Query","query_cost_sum"],"override":{"geometry":"bar"}},{"seriesId":["Log Management & Analytics - Query","query_cost_sum"],"override":{"geometry":"bar"}},{"seriesId":["Traces - Query","query_cost_sum"],"override":{"geometry":"bar"}},{"seriesId":["Events - Query","Cost"],"override":{"geometry":"line"}},{"seriesId":["Log Management & Analytics - Query","Cost"],"override":{"geometry":"line"}},{"seriesId":["Traces - Query","Cost"],"override":{"geometry":"line"}}],"fieldMapping":{"leftAxisValues":["query_cost_sum","Cost"],"timestamp":"timeframe"},"gapPolicy":"connect"},"dataMapping":{"displayedFields":["event.type","query_cost_sum","Cost"]},"autoSelectVisualization":false,"unitsOverrides":[{"identifier":"query_cost_sum","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759851743891},{"identifier":"Cost","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759851762216}]},"querySettings":{"maxResultRecords":1000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":100,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"davisVisualization":{"isAvailable":true}},"timeframe":{"tileTimeframe":{"from":"now()-7d","to":"now()"},"tileTimeframeEnabled":false}},"37":{"title":"DQL Cost by Data Type","type":"data","query":"fetch dt.system.events\n| filter event.kind == \"BILLING_USAGE_EVENT\" and matchesPhrase(event.type, \"Query\")\nAND isNotNull(user.email)\nAND in(event.type,$DataType)\nand in(user.email,$user)\n| fields query_start, event.type, query_id, user.email, billed_bytes\n| summarize bytes = sum(billed_bytes), by:{event.type}\n| summarize array = collectArray(record(`event.type`,bytes)),totalBytes=sum(bytes)\n| expand array\n| fieldsAdd query_totalCost = totalBytes/1024/1024/1024*toDouble($cost), query_cost = array[bytes]/1024/1024/1024*toDouble($cost)\n| fields array[event.type], alias:`Data Type`, round(query_cost, decimals:toLong($decimalPlace)), alias:`Cost`, percentage = (toDouble(query_cost/query_totalCost) * 100)\n| sort percentage desc\n","visualization":"pieChart","visualizationSettings":{"chartSettings":{"truncationMode":"middle","legend":{"hidden":true},"categoricalBarChartSettings":{"valueAxis":"Cost","valueAxisLabel":"Cost","categoryAxis":["Cost","Data Type"],"categoryAxisLabel":"Cost,Data Type"},"circleChartSettings":{"valueType":"relative"}},"autoSelectVisualization":false,"unitsOverrides":[{"identifier":"Cost","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759851648864}]},"querySettings":{"maxResultRecords":1000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":100,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"davisVisualization":{"isAvailable":true}},"timeframe":{"tileTimeframe":{"from":"now()-7d","to":"now()"},"tileTimeframeEnabled":false}},"39":{"title":"Last Month","type":"data","query":"fetch dt.system.events\n| filter event.kind == \"BILLING_USAGE_EVENT\" and matchesPhrase(event.type, \"Query\")\nAND isNotNull(user.email)\nAND in(event.type,$DataType)\nand in(user.email,$user)\n| fields query_start, event.type, query_id, user.email, billed_bytes, timestamp\n| makeTimeseries monthly=sum(billed_bytes/1024/1024/1024), interval:31d\n| fieldsAdd lastmonth = arrayLast(monthly)","visualization":"singleValue","visualizationSettings":{"singleValue":{"labelMode":"none","label":"lastmonth","recordField":"lastmonth","prefixIcon":"","sparklineSettings":{"record":"monthly"},"trend":{"isVisible":true}},"unitsOverrides":[{"identifier":"lastmonth","unitCategory":"data","baseUnit":"gibibyte","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1718620268306}]},"querySettings":{"maxResultRecords":1000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":100,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"enabled":false,"davisVisualization":{"isAvailable":true}},"timeframe":{"tileTimeframeEnabled":true,"tileTimeframe":{"from":"now()-30d","to":"now()"}}},"40":{"title":"Last 7d","type":"data","query":"fetch dt.system.events\n| filter event.kind == \"BILLING_USAGE_EVENT\" and matchesPhrase(event.type, \"Query\")\nAND isNotNull(user.email)\nAND in(event.type,$DataType)\nand in(user.email,$user)\n| fields query_start, event.type, query_id, user.email, billed_bytes, timestamp\n| makeTimeseries weekly=sum(billed_bytes/1024/1024/1024), interval:7d\n| fieldsAdd lastweek = arrayLast(weekly)","visualization":"singleValue","visualizationSettings":{"singleValue":{"labelMode":"none","label":"lastweek","recordField":"lastweek","prefixIcon":"","sparklineSettings":{"record":"weekly"},"trend":{"isVisible":true}},"unitsOverrides":[{"identifier":"lastweek","unitCategory":"data","baseUnit":"gibibyte","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1718620268306}]},"querySettings":{"maxResultRecords":1000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":100,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"enabled":false,"davisVisualization":{"isAvailable":true}},"timeframe":{"tileTimeframeEnabled":true,"tileTimeframe":{"from":"now()-30d","to":"now()"}}},"42":{"title":"Last Month","type":"data","query":"fetch dt.system.events\n| filter event.kind == \"BILLING_USAGE_EVENT\" and matchesPhrase(event.type, \"Query\")\nAND isNotNull(user.email)\nAND in(event.type,$DataType)\nand in(user.email,$user)\n| fields query_start, event.type, query_id, user.email, billed_bytes, timestamp\n| fieldsAdd query_cost = billed_bytes/1024/1024/1024*toDouble($cost)\n| makeTimeseries monthly=sum(query_cost), interval:31d\n| fieldsAdd lastmonth = round(arrayLast(monthly), decimals:toLong($decimalPlace))","visualization":"singleValue","visualizationSettings":{"singleValue":{"labelMode":"none","label":"lastmonth","recordField":"lastmonth","prefixIcon":"","sparklineSettings":{"record":"monthly"},"trend":{"isVisible":true}},"unitsOverrides":[{"identifier":"yesterday","unitCategory":"data","baseUnit":"byte","displayUnit":null,"decimals":1,"suffix":"","delimiter":true,"cascade":null,"added":1718620268306},{"identifier":"monthly","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759851711067},{"identifier":"lastmonth","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759851711442}]},"querySettings":{"maxResultRecords":1000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":100,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"enabled":false,"davisVisualization":{"isAvailable":true}},"timeframe":{"tileTimeframeEnabled":true,"tileTimeframe":{"from":"now()-30d","to":"now()"}}},"43":{"title":"Last 7d","type":"data","query":"fetch dt.system.events\n| filter event.kind == \"BILLING_USAGE_EVENT\" and matchesPhrase(event.type, \"Query\")\nAND isNotNull(user.email)\nAND in(event.type,$DataType)\nand in(user.email,$user)\n| fields query_start, event.type, query_id, user.email, billed_bytes, timestamp\n| fieldsAdd query_cost = billed_bytes/1024/1024/1024*toDouble($cost)\n| makeTimeseries weekly=sum(query_cost), interval:7d\n| fieldsAdd lastweek = round(arrayLast(weekly), decimals:toLong($decimalPlace))","visualization":"singleValue","visualizationSettings":{"singleValue":{"labelMode":"none","label":"lastweek","recordField":"lastweek","prefixIcon":"","sparklineSettings":{"record":"weekly"},"trend":{"isVisible":true}},"unitsOverrides":[{"identifier":"yesterday","unitCategory":"data","baseUnit":"byte","displayUnit":null,"decimals":1,"suffix":"","delimiter":true,"cascade":null,"added":1718620268306},{"identifier":"weekly","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759851692166},{"identifier":"lastweek","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759851692350}]},"querySettings":{"maxResultRecords":1000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":100,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"enabled":false,"davisVisualization":{"isAvailable":true}},"timeframe":{"tileTimeframeEnabled":true,"tileTimeframe":{"from":"now()-30d","to":"now()"}}},"44":{"title":"Last 24h","type":"data","query":"fetch dt.system.events\n| filter event.kind == \"BILLING_USAGE_EVENT\" and matchesPhrase(event.type, \"Query\")\nAND isNotNull(user.email)\nAND in(event.type,$DataType)\nand in(user.email,$user)\n| fields query_start, event.type, query_id, user.email, billed_bytes, timestamp\n| fieldsAdd query_cost = billed_bytes/1024/1024/1024*toDouble($cost)\n| makeTimeseries daily=sum(query_cost), interval:1d\n| fieldsAdd yesterday = round(arrayLast(daily), decimals:toLong($decimalPlace))","visualization":"singleValue","visualizationSettings":{"singleValue":{"labelMode":"none","label":"yesterday","recordField":"yesterday","prefixIcon":"","sparklineSettings":{"record":"daily"},"trend":{"isVisible":true}},"unitsOverrides":[{"identifier":"daily","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759851664622},{"identifier":"yesterday","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759851665033}]},"querySettings":{"maxResultRecords":1000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":100,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"enabled":false,"davisVisualization":{"isAvailable":true}},"timeframe":{"tileTimeframeEnabled":true,"tileTimeframe":{"from":"now()-30d","to":"now()"}}},"46":{"title":"Traces - Cost by User","type":"data","query":"fetch dt.system.events\n| filter event.kind == \"BILLING_USAGE_EVENT\" and matchesPhrase(event.type, \"Query\")\nAND matchesPhrase(event.type,\"Traces - Query\")\nAND isNotNull(user.email)\nand in(user.email,$user)\n| fields query_start, event.type, query_id, user.email, billed_bytes\n| fieldsAdd query_cost = billed_bytes/1024/1024/1024*toDouble($cost)\n| summarize cost = round((sum(query_cost)), decimals:toLong($decimalPlace)), count = count(), by:{user.email,event.type}\n| sort cost desc\n// | fieldsAdd Cost = concat($currency,round(cost, decimals:toLong($decimalPlace))),costAlert = if(cost >= toLong($costAlert),1,else:0)\n| fields user.email, cost\n// | fields user.email, costAlert, alias:`Cost Alert`,totalCostString, alias: `Total Cost($currency)`, records[type], alias:`Type1`, records[count], alias:`Query Count1`, concat($currency,records[cost]), alias:`Cost ($currency)1`\n| limit toLong($limit)","visualization":"pieChart","visualizationSettings":{"chartSettings":{"truncationMode":"middle","legend":{"hidden":true},"categoricalBarChartSettings":{"valueAxis":["cost"],"valueAxisLabel":"cost","categoryAxis":["user.email"],"categoryAxisLabel":"user.email"},"circleChartSettings":{"valueType":"relative","groupingThresholdType":"relative"}},"autoSelectVisualization":false,"unitsOverrides":[{"identifier":"cost","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759851794496}]},"querySettings":{"maxResultRecords":1000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":1,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"enabled":false,"davisVisualization":{"isAvailable":true}}},"47":{"title":"Events - Cost by User","type":"data","query":"fetch dt.system.events\n| filter event.kind == \"BILLING_USAGE_EVENT\" and matchesPhrase(event.type, \"Query\")\nAND matchesPhrase(event.type,\"Events - Query\")\nAND isNotNull(user.email)\nand in(user.email,$user)\n| fields query_start, event.type, query_id, user.email, billed_bytes\n| fieldsAdd query_cost = billed_bytes/1024/1024/1024*toDouble($cost)\n| summarize cost = round((sum(query_cost)), decimals:toLong($decimalPlace)), count = count(), by:{user.email,event.type}\n| sort cost desc\n// | fieldsAdd Cost = concat($currency,round(cost, decimals:toLong($decimalPlace))),costAlert = if(cost >= toLong($costAlert),1,else:0)\n| fields user.email, cost\n// | fields user.email, costAlert, alias:`Cost Alert`,totalCostString, alias: `Total Cost($currency)`, records[type], alias:`Type1`, records[count], alias:`Query Count1`, concat($currency,records[cost]), alias:`Cost ($currency)1`\n| limit toLong($limit)","visualization":"pieChart","visualizationSettings":{"chartSettings":{"truncationMode":"middle","legend":{"hidden":true},"categoricalBarChartSettings":{"valueAxis":["cost"],"valueAxisLabel":"cost","categoryAxis":["user.email"],"categoryAxisLabel":"user.email"},"circleChartSettings":{"valueType":"relative","groupingThresholdType":"relative"}},"autoSelectVisualization":false,"unitsOverrides":[{"identifier":"cost","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759851785242}]},"querySettings":{"maxResultRecords":1000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":1,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"enabled":false,"davisVisualization":{"isAvailable":true}}},"48":{"title":"Log Management & Analytics - Cost by User","type":"data","query":"fetch dt.system.events\n| filter event.kind == \"BILLING_USAGE_EVENT\" and matchesPhrase(event.type, \"Query\")\nAND matchesPhrase(event.type,\"Log Management & Analytics - Query\")\nAND isNotNull(user.email)\nand in(user.email,$user)\n| fields query_start, event.type, query_id, user.email, billed_bytes\n| fieldsAdd query_cost = billed_bytes/1024/1024/1024*toDouble($cost)\n| summarize cost = round((sum(query_cost)), decimals:toLong($decimalPlace)), count = count(), by:{user.email,event.type}\n| sort cost desc\n// | fieldsAdd Cost = concat($currency,round(cost, decimals:toLong($decimalPlace))),costAlert = if(cost >= toLong($costAlert),1,else:0)\n| fields user.email, cost\n// | fields user.email, costAlert, alias:`Cost Alert`,totalCostString, alias: `Total Cost($currency)`, records[type], alias:`Type1`, records[count], alias:`Query Count1`, concat($currency,records[cost]), alias:`Cost ($currency)1`\n| limit toLong($limit)","visualization":"pieChart","visualizationSettings":{"chartSettings":{"truncationMode":"middle","legend":{"hidden":true},"categoricalBarChartSettings":{"valueAxis":["cost"],"valueAxisLabel":"cost","categoryAxis":["user.email"],"categoryAxisLabel":"user.email"},"circleChartSettings":{"valueType":"relative","groupingThresholdType":"relative"}},"autoSelectVisualization":false,"unitsOverrides":[{"identifier":"cost","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759851775241}]},"querySettings":{"maxResultRecords":1000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":1,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"enabled":false,"davisVisualization":{"isAvailable":true}}},"49":{"title":"Total Cost per User","type":"data","query":"fetch dt.system.events\n| filter event.kind == \"BILLING_USAGE_EVENT\" and matchesPhrase(event.type, \"Query\")\nAND isNotNull(user.email)\nAND in(event.type,$DataType)\nand in(user.email,$user)\n| fields query_start, event.type, query_id, user.email, billed_bytes\n| fieldsAdd query_cost = billed_bytes/1024/1024/1024*toDouble($cost)\n| summarize cost = round((sum(query_cost)), decimals:toLong($decimalPlace)), count = count(), by:{user.email,event.type}\n| summarize records = collectArray(record(cost, count, type=event.type)), total = sum(cost), by:{user.email}\n| fieldsAdd totalCost =round(total, decimals:toLong($decimalPlace)),\ncostAlert = if(total >= toLong($costAlert),1,else:0)\n| sort totalCost desc\n| fields user.email, costAlert, alias:`Cost Alert`,totalCost, alias: `Total Cost`, records[0][type], alias:`Type1`, records[0][count], alias:`Query Count1`, records[0][cost], alias:`Cost 1`,\nrecords[1][type], alias:`Type2`, records[1][count], alias:`Query Count2`, records[1][cost], alias:`Cost 2`,\nrecords[2][type], alias:`Type3`, records[2][count], alias:`Query Count3`, records[2][cost], alias:`Cost 3`\n| limit toLong($limit)","visualization":"table","visualizationSettings":{"table":{"hiddenColumns":[["Cost Alert"]],"linewrapEnabled":true,"rowDensity":"comfortable","lineWrapIds":[["user.email"],["Total Cost(\"$\")"],["Type1"],["Query Count1"],["Cost (\"$\")1"],["Type2"],["Query Count2"],["Cost (\"$\")2"],["Type3"],["Query Count3"],["Cost (\"$\")3"]],"sortBy":{"columnId":"[\"Total Cost(\\\"$\\\")\"]","direction":"descending"},"columnWidths":{"[\"Cost Alert\"]":115.59375,"[\"user.email\"]":281.5694580078125,"[\"Type1\"]":126.72,"[\"Type2\"]":175.71,"[\"Total Cost(\\\"$\\\")\"]":136.8,"[\"Query Count1\"]":116.68,"[\"Cost (\\\"$\\\")1\"]":92.97915649414062,"[\"Query Count2\"]":86.6875,"[\"Cost (\\\"$\\\")2\"]":102.97917175292969,"[\"Query Count3\"]":91.70834350585938,"[\"Total Cost\"]":143.79}},"coloring":{"colorRules":[{"value":0,"comparator":"=","field":"Cost Alert","colorMode":"custom-color","customColor":{"Default":"var(--dt-colors-charts-status-ideal-default, #2f6863)"},"metadata":{"applyTo":"row"}},{"value":1,"comparator":"=","field":"Cost Alert","colorMode":"custom-color","customColor":{"Default":"var(--dt-colors-charts-status-critical-default, #c4233b)"},"metadata":{"applyTo":"row"}}]},"autoSelectVisualization":false,"unitsOverrides":[{"identifier":"Total Cost(\"$\")","unitCategory":"unspecified","baseUnit":"none","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1738174772197},{"identifier":"Total Cost","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759356955882},{"identifier":"Cost 1","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759356956059},{"identifier":"Cost 2","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759356956215},{"identifier":"Cost 3","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759356956801}]},"querySettings":{"maxResultRecords":100000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":100,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"davisVisualization":{"isAvailable":true}}},"52":{"title":"Cost by App","type":"data","query":"fetch dt.system.events\n| filter event.kind == \"BILLING_USAGE_EVENT\" and matchesPhrase(event.type, \"Query\")\nAND isNotNull(user.email)\nAND in(event.type,$DataType)\nand in(user.email,$user)\n| fields query_start, event.type, query_id, user.email, billed_bytes, timestamp, query_string\n| fieldsAdd gb = billed_bytes/1024/1024/1024\n| fieldsAdd query_cost = gb*toDouble($cost) \n| join [\n fetch dt.system.query_executions\n | filter isNotNull(user.email) \n AND not(in(bucket, \"default_davis_events\",\"dt_system_metrics\",\"default_davis_k8s_ops_events\",\"default_davis_custom_events\",\"default_security_custom_events\",\"default_security_events\",\"default_synthetic_events\",\"default_synthetic_detailed_events\",\"default_selfmon_events\")) \n AND isNotNull(bucket)\n AND bucket != \"\"\n AND status == \"SUCCEEDED\"\n AND scanned_bytes > 0\n AND (isNotNull(client.application_context) or isNotNull(client.internal_service_context))\n and isNotNull(query_id)\n | parse client.source,\"LD:link ('?'|EOS)\"\n | fieldsAdd client.source = client.source\n // AND isNotNull(client.source)\n],\n on: query_id,\n prefix: \"executiondata.\",\n kind:inner\n| fieldsAdd app = if(isNotNull(executiondata.client.application_context)\n ,executiondata.client.application_context\n ,else:executiondata.client.internal_service_context), function = executiondata.client.function_context, link = executiondata.link, source = executiondata.client.source\n| summarize Cost = round((sum(query_cost)), decimals:toLong($decimalPlace)),GiB = round(sum(gb), decimals:toLong($decimalPlace)), executions=count(), by:{app, function, link, source}\n| sort Cost desc\n| fieldsAdd costAlert = if(Cost >= toDouble($costAlert), 1, else:0)\n| fieldsAdd url = if(app == \"dynatrace.davis.anomalydetection\", concat(\"[\",app,\"](https://{environmentid}.apps.dynatrace.com/ui/apps/dynatrace.davis.anomalydetection/intent/open_anomaly_detector_schema#%7B%22dt.settings.object_id%22%3A%22\",source,\"%22%2C%22dt.settings.schema_id%22%3A%22builtin%3Adavis.anomaly-detectors%22%7D)\"),else:concat(\"[\",app,\"]\",\"(\",link,\")\"))\n\n// | fieldsAdd url = concat(\"[\",executiondata.client.source,\"](https://{environmentid}.apps.dynatrace.com/ui/apps/dynatrace.davis.anomalydetection/intent/open_anomaly_detector_schema#%7B%22dt.settings.object_id%22%3A%22\",executiondata.client.source,\"%22%2C%22dt.settings.schema_id%22%3A%22builtin%3Adavis.anomaly-detectors%22%7D)\")\n| fields app, url, costAlert, Cost, GiB, executions\n| filter GiB > 0\n| limit toLong($limit)","visualization":"table","visualizationSettings":{"table":{"columnOrder":["[\"app\"]","[\"url\"]","[\"costAlert\"]","[\"Cost\"]","[\"GiB\"]","[\"executions\"]"],"columnTypeOverrides":[{"id":504448.8999999999,"fields":["url"],"value":"markdown"}],"hiddenColumns":[["costAlert"]],"columnWidths":{"[\"App\"]":350.125,"[\"Gigabyte\"]":84.8125,"[\"costAlert\"]":67.4375,"[\"url\"]":240,"[\"executiondata.client.source\"]":1393,"[\"Cost\"]":81,"[\"app\"]":221}},"coloring":{"colorRules":[{"value":0,"comparator":"=","field":"costAlert","colorMode":"custom-color","customColor":{"Default":"var(--dt-colors-charts-status-ideal-default, #2f6863)"},"metadata":{"applyTo":"row"}},{"value":1,"comparator":"=","field":"costAlert","colorMode":"custom-color","customColor":{"Default":"var(--dt-colors-charts-status-critical-default, #c4233b)"},"metadata":{"applyTo":"row"}}]},"autoSelectVisualization":false,"unitsOverrides":[{"identifier":"GiB","unitCategory":"data","baseUnit":"gibibyte","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1738174508912},{"identifier":"Cost","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759356576504}]},"querySettings":{"maxResultRecords":100000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":100,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"davisVisualization":{"isAvailable":true}}},"53":{"title":"Cost by Dashboard/Notebook","type":"data","query":"fetch dt.system.events\n| filter event.kind == \"BILLING_USAGE_EVENT\" and matchesPhrase(event.type, \"Query\")\nAND isNotNull(user.email)\nAND in(event.type,$DataType)\nand in(user.email,$user)\n| fields query_start, event.type, query_id, user.email, billed_bytes, timestamp, query_string\n| fieldsAdd gb = billed_bytes/1024/1024/1024\n| fieldsAdd query_cost = gb*toDouble($cost) \n| lookup [\n fetch dt.system.query_executions\n | filter isNotNull(user.email) \n AND not(in(bucket, \"default_davis_events\",\"dt_system_metrics\",\"default_davis_k8s_ops_events\",\"default_davis_custom_events\",\"default_security_custom_events\",\"default_security_events\",\"default_synthetic_events\",\"default_synthetic_detailed_events\",\"default_selfmon_events\")) \n AND isNotNull(bucket)\n AND bucket != \"\"\n AND status == \"SUCCEEDED\"\n AND scanned_bytes > 0\n AND isNotNull(client.application_context) AND isNotNull(client.source)\n AND in(client.application_context,\"dynatrace.notebooks\",\"dynatrace.dashboards\")\n],\n sourceField: query_id,\n lookupField: query_id,\n prefix: \"executiondata.\",\n executionOrder:leftFirst\n| sort timestamp desc\n| parse executiondata.client.source,\"LD '/ui/' LD:type '/' LD:id\"\n// //| parse client.application_context,\"'dynatrace.' LD:type 's'\"\n| filter isNotNull(id)\n// //| fieldsAdd length = stringLength(client.application_context)\n| fieldsAdd link = concat(\"[\",executiondata.client.application_context,\"]\",\"(https://{environmentid}.apps.dynatrace.com/ui/apps/\",executiondata.client.application_context,\"/\",type,\"/\",id,\")\")\n// // | fieldsRemove scanned_bytes\n| summarize Cost = round((sum(query_cost)), decimals:toLong($decimalPlace)),GiB = round(sum(gb), decimals:toLong($decimalPlace)), by:{executiondata.client.application_context, id, link}\n| fieldsAdd costAlert = if(Cost >= toDouble($costAlert), 1, else:0)\n| filterOut Cost <= 0\n| sort Cost desc\n| fields id, link, costAlert, Cost, GiB\n| limit toLong($limit)","visualization":"table","visualizationSettings":{"table":{"hiddenColumns":[["costAlert"]],"lineWrapIds":[["id"],["link"]],"sortBy":[{"columnId":"[\"id\"]","direction":"ascending"}],"columnWidths":{"[\"id\"]":282,"[\"Cost\"]":85},"columnTypeOverrides":[{"id":185949.1000000015,"fields":["link"],"value":"markdown"}]},"coloring":{"colorRules":[{"value":0,"comparator":"=","field":"costAlert","colorMode":"custom-color","customColor":{"Default":"var(--dt-colors-charts-status-ideal-default, #2f6863)"},"metadata":{"applyTo":"row"}},{"value":1,"comparator":"=","field":"costAlert","colorMode":"custom-color","customColor":{"Default":"var(--dt-colors-charts-status-critical-default, #c4233b)"},"metadata":{"applyTo":"row"}}]},"unitsOverrides":[{"identifier":"GiB","unitCategory":"data","baseUnit":"gibibyte","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1738174421522},{"identifier":"Cost","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759357024938}]},"querySettings":{"maxResultRecords":100000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":100,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"davisVisualization":{"isAvailable":true}}},"54":{"title":"Cost by Bucket","type":"data","query":"fetch dt.system.events\n| filter event.kind == \"BILLING_USAGE_EVENT\" and matchesPhrase(event.type, \"Query\")\nAND isNotNull(user.email)\nAND in(event.type,$DataType)\nand in(user.email,$user)\n| fields query_start, event.type, query_id, user.email, billed_bytes, timestamp, query_string\n| fieldsAdd gb = billed_bytes/1024/1024/1024\n| fieldsAdd query_cost = gb*toDouble($cost) \n| lookup [\n fetch dt.system.query_executions\n | filter isNotNull(user.email) \n and not(in(bucket, \"default_davis_events\",\"dt_system_metrics\",\"default_davis_k8s_ops_events\",\"default_davis_custom_events\",\"default_security_custom_events\",\"default_security_events\",\"default_synthetic_events\",\"default_synthetic_detailed_events\",\"default_selfmon_events\")) \n and isNotNull(bucket)\n and bucket != \"\"\n and status == \"SUCCEEDED\"\n and scanned_bytes > 0\n],\n sourceField: query_id,\n lookupField: query_id,\n prefix: \"executiondata.\",\n executionOrder:leftFirst\n| sort timestamp desc\n| summarize Cost = round((sum(query_cost)), decimals:toLong($decimalPlace)), GiB = round(sum(gb), decimals:toLong($decimalPlace)),executions = count(), by: {bucket = executiondata.bucket}\n| sort Cost desc\n| fieldsAdd costAlert = if(Cost >= toDouble($costAlert), 1, else:0)\n| fields bucket, costAlert, Cost, GiB, executions\n| filter GiB > 0\n| limit toLong($limit)\n","visualization":"table","visualizationSettings":{"table":{"hiddenColumns":[["costAlert"]],"columnWidths":{"[\"Gigabyte\"]":172.8125,"[\"Cost\"]":122.20442199707031}},"coloring":{"colorRules":[{"value":0,"comparator":"=","field":"costAlert","colorMode":"custom-color","customColor":{"Default":"var(--dt-colors-charts-status-ideal-default, #2f6863)"},"metadata":{"applyTo":"row"}},{"value":1,"comparator":"=","field":"costAlert","colorMode":"custom-color","customColor":{"Default":"var(--dt-colors-charts-status-critical-default, #c4233b)"},"metadata":{"applyTo":"row"}}]},"unitsOverrides":[{"identifier":"GiB","unitCategory":"data","baseUnit":"gibibyte","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1738174457736},{"identifier":"Cost","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759357017269}]},"querySettings":{"maxResultRecords":1000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":100,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"davisVisualization":{"isAvailable":true}}},"56":{"title":"AVG Cost & GB per Execution (Optimization Opportunity)","type":"data","query":"fetch dt.system.events\n| filter event.kind == \"BILLING_USAGE_EVENT\" and matchesPhrase(event.type, \"Query\")\nAND isNotNull(user.email)\nAND in(event.type,$DataType)\nand in(user.email,$user)\n| fields query_start, event.type, query_id, user.email, billed_bytes\n| fieldsAdd gb = billed_bytes/1024/1024/1024\n| fieldsAdd query_cost = gb*toDouble($cost)\n| summarize cost = round((sum(query_cost)), decimals:toLong($decimalPlace)), count = count(), gb = sum(gb), by:{user.email} \n| fieldsAdd costPerExecutionAvg = cost/count, gbPerExecutionAvg = gb/count\n| sort costPerExecutionAvg desc\n| fieldsAdd costAvgPerExecution = if(costPerExecutionAvg >= toDouble($costAvgExecutionAlert), 1, else:0)\n| fields user.email, costAvgPerExecution, cost = round(costPerExecutionAvg,decimals:toLong($decimalPlace)), GiB = round(gbPerExecutionAvg, decimals:toLong($decimalPlace))\n| filter GiB > 0\n| limit toLong($limit)","visualization":"table","visualizationSettings":{"table":{"hiddenColumns":[["costAvgPerExecution"]],"columnWidths":{"[\"user.email\"]":208.25,"[\"costAvgPerExecution\"]":124.47917175292969}},"coloring":{"colorRules":[{"value":0,"comparator":"≥","field":"costAvgPerExecution","colorMode":"custom-color","customColor":{"Default":"var(--dt-colors-charts-status-ideal-default, #2f6863)"},"metadata":{"applyTo":"row"}},{"value":1,"comparator":"≥","field":"costAvgPerExecution","colorMode":"custom-color","customColor":{"Default":"var(--dt-colors-charts-status-critical-default, #c4233b)"},"metadata":{"applyTo":"row"}}]},"unitsOverrides":[{"identifier":"GiB","unitCategory":"data","baseUnit":"gibibyte","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1738174587669},{"identifier":"cost","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759356542938}]},"querySettings":{"maxResultRecords":1000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":100,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"davisVisualization":{"isAvailable":true}}},"57":{"title":"Un-optimized DQL","type":"data","query":"fetch dt.system.events\n| filter event.kind == \"BILLING_USAGE_EVENT\" and matchesPhrase(event.type, \"Query\")\nAND isNotNull(user.email)\nAND in(event.type,$DataType)\nand in(user.email,$user)\n| fields query_start, event.type, query_id, user.email, billed_bytes, timestamp, query_string\n| fieldsAdd gb = billed_bytes/1024/1024/1024\n| fieldsAdd query_cost = gb*toDouble($cost) \n| lookup [\n fetch dt.system.query_executions\n | filter isNotNull(user.email) \n and not(in(bucket, \"default_davis_events\",\"dt_system_metrics\",\"default_davis_k8s_ops_events\",\"default_davis_custom_events\",\"default_security_custom_events\",\"default_security_events\",\"default_synthetic_events\",\"default_synthetic_detailed_events\",\"default_selfmon_events\")) \n and isNotNull(bucket)\n and bucket != \"\"\n and status == \"SUCCEEDED\"\n and scanned_bytes > 0\n and isNotNull(query_string)\n | filterOut (contains(query_string, \"filter\") AND matchesRegex(query_string,\"\\\\\\\\w+\\\\\\\\s*==\\\\\\\\s*\\\\\\\"*\\\\\\\"\"))\n OR not(contains(query,\"scanLimitGBytes:-1\")) \n OR contains(query_string,\"filterOut\")\n OR contains(query_string,\"from:\")\n OR contains(query_string, \"samplingRatio\")\n OR contains(query_string, \"experimentalFieldsSummary\")\n OR contains(query_string, \"limit\")\n],\n sourceField: query_id,\n lookupField: query_id,\n prefix: \"executiondata.\",\n executionOrder:leftFirst\n| sort timestamp desc\n| summarize Cost = round((sum(query_cost)), decimals:toLong($decimalPlace)), GiB = round(sum(gb), decimals:toLong($decimalPlace)),executions = count(), by: {query = executiondata.query_string}\n| filter isNotNull(query)\n| sort Cost desc\n| fieldsAdd costAlert = if(Cost >= toDouble($costAlert), 1, else:0)\n| fields query, costAlert, Cost, GiB, executions\n| filter GiB > 0\n| limit toLong($limit)","visualization":"table","visualizationSettings":{"table":{"hiddenColumns":[["costAlert"]],"lineWrapIds":[["query"]],"sortBy":[{"columnId":"[\"Cost\"]","direction":"descending"}],"columnWidths":{"[\"query\"]":343,"[\"Gigabyte\"]":104,"[\"costAlert\"]":104}},"coloring":{"colorRules":[{"value":0,"comparator":"=","field":"costAlert","colorMode":"custom-color","customColor":{"Default":"var(--dt-colors-charts-status-ideal-default, #2f6863)"},"metadata":{"applyTo":"row"}},{"value":1,"comparator":"=","field":"costAlert","colorMode":"custom-color","customColor":{"Default":"var(--dt-colors-charts-status-critical-default, #c4233b)"},"metadata":{"applyTo":"row"}}]},"autoSelectVisualization":false,"unitsOverrides":[{"identifier":"GiB","unitCategory":"data","baseUnit":"gibibyte","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1738174566848},{"identifier":"Cost","unitCategory":"currency","baseUnit":"usd","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759356555871}]},"querySettings":{"maxResultRecords":100000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":100,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"davisVisualization":{"isAvailable":true}}},"58":{"title":"Most Expensive Queries","type":"data","query":"fetch dt.system.events\n| filter event.kind == \"BILLING_USAGE_EVENT\" and matchesPhrase(event.type, \"Query\")\nAND isNotNull(user.email)\nAND in(event.type,$DataType)\nand in(user.email,$user)\n| fields query_start, event.type, query_id, user.email, billed_bytes, timestamp, query_string, client.application_context, client.source\n| fieldsAdd gb = billed_bytes/1024/1024/1024\n| fieldsAdd query_cost = gb*toDouble($cost) \n| lookup [\n fetch dt.system.query_executions\n | filter isNotNull(user.email) \n and not(in(bucket, \"default_davis_events\",\"dt_system_metrics\",\"default_davis_k8s_ops_events\",\"default_davis_custom_events\",\"default_security_custom_events\",\"default_security_events\",\"default_synthetic_events\",\"default_synthetic_detailed_events\",\"default_selfmon_events\")) \n and isNotNull(bucket)\n and bucket != \"\"\n and status == \"SUCCEEDED\"\n and scanned_bytes > 0\n and isNotNull(query_string)\n and query_string != \"\"\n],\n sourceField: query_id,\n lookupField: query_id,\n prefix: \"executiondata.\",\n executionOrder:leftFirst\n| parse client.source,\"LD '/ui/' LD:type '/' LD:id\"\n| fieldsAdd link = concat(\"[\",client.application_context,\"]\",\"(https://{environmentid}.apps.dynatrace.com/ui/apps/\",client.application_context,\"/\",type,\"/\",id,\")\") \n| sort timestamp desc\n| summarize Cost = round((sum(query_cost)), decimals:toLong($decimalPlace)), GiB = round(sum(gb), decimals:toLong($decimalPlace)),executions = count(), by: {query = executiondata.query_string, link}\n| sort Cost desc\n| fieldsAdd costAlert = if(Cost >= toDouble($costAlert), 1, else:0)\n| fields query, costAlert, Cost, GiB, executions, link\n| filter GiB > 0\n| limit toLong($limit)","visualization":"table","visualizationSettings":{"table":{"hiddenColumns":[["costAlert"]],"lineWrapIds":[["query"]],"sortBy":[{"columnId":"[\"client.application_context\"]","direction":"ascending"}],"columnTypeOverrides":[{"id":465735,"fields":["link"],"value":"markdown","disableRemoval":false}],"columnWidths":{"[\"Cost\"]":47.7}},"coloring":{"colorRules":[{"value":0,"comparator":"=","field":"costAlert","colorMode":"custom-color","customColor":{"Default":"var(--dt-colors-charts-status-ideal-default, #2f6863)"},"metadata":{"applyTo":"row"},"type":"long"},{"value":1,"comparator":"=","field":"costAlert","colorMode":"custom-color","customColor":{"Default":"var(--dt-colors-charts-status-critical-default, #c4233b)"},"metadata":{"applyTo":"row"},"type":"long"}]},"unitsOverrides":[{"identifier":"GiB","unitCategory":"data","baseUnit":"gibibyte","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1738174544061}]},"querySettings":{"maxResultRecords":100000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":100,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"davisVisualization":{"isAvailable":true}}},"60":{"type":"markdown","content":"DQL Usage Overview version: *$version*"},"61":{"title":"Last 24h","type":"data","query":"fetch dt.system.events\n| filter event.kind == \"BILLING_USAGE_EVENT\" and matchesPhrase(event.type, \"Query\")\nAND isNotNull(user.email)\nAND in(event.type,$DataType)\nand in(user.email,$user)\n| fields query_start, event.type, query_id, user.email, billed_bytes, timestamp\n| makeTimeseries daily=sum(billed_bytes/1024/1024/1024), interval:1d\n| fieldsAdd yesterday = arrayLast(daily)","visualization":"singleValue","visualizationSettings":{"singleValue":{"labelMode":"none","label":"yesterday","recordField":"yesterday","prefixIcon":"","sparklineSettings":{"record":"daily"},"trend":{"isVisible":true}},"unitsOverrides":[{"identifier":"yesterday","unitCategory":"data","baseUnit":"gibibyte","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1718620268306}]},"querySettings":{"maxResultRecords":1000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":100,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"enabled":false,"davisVisualization":{"isAvailable":true}},"timeframe":{"tileTimeframeEnabled":true,"tileTimeframe":{"from":"now()-30d","to":"now()"}}},"62":{"title":"DQL Cost","type":"data","query":"fetch dt.system.events\n| filter event.kind == \"BILLING_USAGE_EVENT\" and matchesPhrase(event.type, \"Query\")\nAND isNotNull(user.email)\nAND in(event.type,$DataType)\nand in(user.email,$user)\n| fields query_start, event.type, query_id, user.email, billed_bytes, timestamp\n| fieldsAdd query_cost = billed_bytes/1024/1024/1024*toDouble($cost)\n| makeTimeseries cost = sum(query_cost)\n| fieldsAdd totalCost = round(arraySum(cost),decimals:toLong($decimalPlace))","visualization":"singleValue","visualizationSettings":{"singleValue":{"labelMode":"none","label":"totalCost","recordField":"totalCost","prefixIcon":"","sparklineSettings":{"record":"cost"},"trend":{"isVisible":true}},"unitsOverrides":[{"identifier":"yesterday","unitCategory":"data","baseUnit":"byte","displayUnit":null,"decimals":1,"suffix":"","delimiter":true,"cascade":null,"added":1718620268306},{"identifier":"cost","unitCategory":"currency","baseUnit":"eur","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759851609664},{"identifier":"totalCost","unitCategory":"currency","baseUnit":"eur","displayUnit":null,"decimals":2,"suffix":"","delimiter":false,"cascade":null,"added":1759851638123}]},"querySettings":{"maxResultRecords":1000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":100,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"enabled":false,"davisVisualization":{"isAvailable":true}},"timeframe":{"tileTimeframe":{"from":"now()-30d","to":"now()"},"tileTimeframeEnabled":false}},"63":{"title":"","type":"data","query":"data record(text=\"Optimization Opportunity\")","visualization":"singleValue","visualizationSettings":{"singleValue":{"labelMode":"none","label":"text","recordField":"text","isIconVisible":true,"prefixIcon":"DqlSignetIcon","colorThresholdTarget":"background","trend":{"isVisible":false}},"coloring":{"colorRules":[{"value":"Optimization Opportunity","comparator":"≥","field":"text","colorMode":"custom-color","customColor":{"Default":"var(--dt-colors-charts-categorical-color-09-default, #649438)"}}]},"autoSelectVisualization":false},"querySettings":{"maxResultRecords":1000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":1,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"enabled":false,"davisVisualization":{"isAvailable":true}}},"64":{"title":"","type":"data","query":"data record(text=\"Deep-Dive\")","visualization":"singleValue","visualizationSettings":{"singleValue":{"labelMode":"none","label":"text","recordField":"text","isIconVisible":true,"prefixIcon":"DqlSignetIcon","colorThresholdTarget":"background","trend":{"isVisible":false}},"coloring":{"colorRules":[{"value":"Deep-Dive","comparator":"≥","field":"text","colorMode":"custom-color","customColor":{"Default":"var(--dt-colors-charts-categorical-color-11-default, #627cfe)"}}]},"autoSelectVisualization":false},"querySettings":{"maxResultRecords":1000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":1,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"enabled":false,"davisVisualization":{"isAvailable":true}}},"65":{"title":"","type":"data","query":"data record(text=\"User Analysis\")","visualization":"singleValue","visualizationSettings":{"singleValue":{"labelMode":"none","label":"text","recordField":"text","isIconVisible":true,"prefixIcon":"DqlSignetIcon","colorThresholdTarget":"background","trend":{"isVisible":false}},"coloring":{"colorRules":[{"value":"User Analysis","comparator":"≥","field":"text","colorMode":"custom-color","customColor":{"Default":"var(--dt-colors-charts-loglevel-alert-default, #c73d84)"}}]},"autoSelectVisualization":false},"querySettings":{"maxResultRecords":1000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":1,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"enabled":false,"davisVisualization":{"isAvailable":true}}},"66":{"title":"","type":"data","query":"data record(text=\"Daily/Weekly/Monthly (Usage (GiB) and Costs)\")","visualization":"singleValue","visualizationSettings":{"singleValue":{"labelMode":"none","label":"text","recordField":"text","isIconVisible":true,"prefixIcon":"DqlSignetIcon","colorThresholdTarget":"background","trend":{"isVisible":false}},"coloring":{"colorRules":[{"value":"Daily/Weekly/Monthly (Usage (GiB) and Costs)","comparator":"≥","field":"text","colorMode":"custom-color","customColor":{"Default":"var(--dt-colors-charts-categorical-color-07-default, #438fb1)"}}]},"autoSelectVisualization":false},"querySettings":{"maxResultRecords":1000,"defaultScanLimitGbytes":500,"maxResultMegaBytes":1,"defaultSamplingRatio":10,"enableSampling":false},"davis":{"enabled":false,"davisVisualization":{"isAvailable":true}}}},"layouts":{"34":{"x":5,"y":0,"w":7,"h":4},"36":{"x":5,"y":4,"w":7,"h":3},"37":{"x":0,"y":4,"w":5,"h":3},"39":{"x":20,"y":1,"w":4,"h":3},"40":{"x":16,"y":1,"w":4,"h":3},"42":{"x":20,"y":4,"w":4,"h":3},"43":{"x":16,"y":4,"w":4,"h":3},"44":{"x":12,"y":4,"w":4,"h":3},"46":{"x":0,"y":16,"w":6,"h":4},"47":{"x":0,"y":12,"w":6,"h":4},"48":{"x":0,"y":8,"w":6,"h":4},"49":{"x":6,"y":8,"w":18,"h":12},"52":{"x":16,"y":21,"w":8,"h":6},"53":{"x":0,"y":21,"w":8,"h":6},"54":{"x":8,"y":21,"w":8,"h":6},"56":{"x":16,"y":28,"w":8,"h":6},"57":{"x":8,"y":28,"w":8,"h":6},"58":{"x":0,"y":28,"w":8,"h":6},"60":{"x":0,"y":34,"w":9,"h":1},"61":{"x":12,"y":1,"w":4,"h":3},"62":{"x":0,"y":0,"w":5,"h":4},"63":{"x":0,"y":27,"w":24,"h":1},"64":{"x":0,"y":20,"w":24,"h":1},"65":{"x":0,"y":7,"w":24,"h":1},"66":{"x":12,"y":0,"w":12,"h":1}},"importedWithCode":false,"settings":{},"annotations":[]}
