Alert for Azure monitoring unavailable
Hi
Due to some network changes we experienced that our configuration for Azure monitoring became unavailable. We did not receive any notification about this, and frankly the only hint I got was when I tried to re-save the existing configuration. I was then told that the Active Gate was unable to communicate with the Azure subscription.
How do I set up alerting for this scenario?
Best regards
Rasmus
Maybe another people have a better solution, but you can:
  1. Create a metric event base on Azure metric.
  2. Enable “Alert on missing data”.
Best regards
