In one of my environments, I need to send an alert when metrics are not sent from Azure to Dynatrace. I have a basic integration with Azure configured and am collecting information about the VMs (CPU, memory, disk). Unfortunately, no metrics are available to inform me, for example, that a VM has been shut down or restarted. We have prepared a metrics event that has the “Alert in missing data” option enabled.
builtin:cloud.azure.vm.cpuUsage:filter(and(not(in(“dt.entity.azure_vms,entitySelector(“type(azure_vm),tag(~”(Azure)V:XXXX~”)"))))):splitBy(“dt.entity.azure_vm”)))
Of course, the threshold is 101% CPU utilisation so that it does not report other deviations.
The preview shows correct operation. Unfortunately when running in a production environment the alerts are reported randomly and close a minute later. This happens for several vm’s at the same time. The time windows are set as shown in the screenshot:
Radek
