Hello Support,
We have Azure integration set up in Dynatrace with the required Reader and Monitoring Reader roles. Most resources are monitored fine, but two resource types show no metrics:
- Event Hubs Namespace (Microsoft.EventHub/namespaces) – Metrics like IncomingRequests, OutgoingMessages, etc. are visible in Azure Monitor but not in Dynatrace. We can see the data in Event hubs - but we are expecting the main class as in event hubs it showing the list of entries but the main 10-12 namspace not reflecting in namespace option in azure integration page. If the activage version is factor then do suggest what can be do further as we have Azure Service Bus will be disabled for Environment ActiveGate version 1.245+ and Dynatrace version 1.247+(we have this AG’s)
- Azure Virtual Networks Gateway(Microsoft.Network/virtualNetworks) – Only inventory is shown, no metrics.The Azure virtual network gateway service is already added in managaed service option on azure integration page. I can see this service listed there also it shows it consist 5-6 metrics as predefine but when it not appears in azure integration view as i checked all option available there. The Virtual networks are there in azure side as shared by client side but why it’s not reflecting in dynatrace azure integration page. I tried to search the metric for it but no luck.
- Can you please confirm what can be done to achieve this?
Could you confirm:
- Are these resource types supported for Azure Monitor metric ingestion in Dynatrace?
- If not, is there a workaround support?
Gaurav Payghan
Kindly look into it @azzollinigianlu @dynamite
jason_gs@gaddenna_n_k @dannemca @Michal_Gebacki @dynadynat@florian_g @Mizső
