Azure EventHUB namespace missing metrics
Hi Folks,
There is a product idea regarding a missing EventHUB namespace metrics.
Missing Azure Eventhub Namespace Metric - Dynatrace Community
Is there any workaround to collect this namespace size metric from the Azure EventHUB until the official soultion?
Thanks in advance.
Best regards,
János
Hi @Mizső 🙂
Have you tried feeding Dynatrace by fetching the size of virtual machines via the Azure API?
Radek
Hi @radek_jasinski
Thank you very much. I am going ot check this metric with the client.
Best regards,
János
