We have identified an issue with some of our applications that they will sometimes restart several times in a short period of time. The application becomes available until the next time some execution causes it to restart again. Is there a way to alert when a process restarts x number of times in a period? I see we can check if x number of processes are available or if the process becomes unavailable. I checked to see if the restart events where available in charting to see if I could create a custom event but I can’t locate a metric within there.
Hello @Michael P.
At the moment this option is not available. You can open an RFE to include this feature.
Babar
Hi @Michael P.
If those restarts are listed in logs can set Custom metrics for Log Monitoring and set custom alert on them
HTH
Yos
Hi @Yos N. These are Azure app services which currently Dynatrace does not capture the logs.
Hi @Michael P.
So there is no logs
, stand corrected.
Just a naive question for dummies like me that do not know Azure, can those restart be set as Azure alert and retrieve them with setting of metric events for alerting under Azure Monitor?
Yos
And from glancing over the fresh new blog , its look like logs will be also available for Azure in the near feature.
