Alert Process restarted
Is it possible to create alerts for processes that are being restarted?
Thanks.
Hello @mauricio_capiz
Please have a look at the below link for the process group availability monitoring and alerting.
Babar
Hello Babar,
Thanks for the quick reply
I followed the steps of a similar post, but for some reason it did not work:
In fact I did not raise a problem, is there something else I should do?
Attached an image of the active configuration
Thanks.
You can configure the availability event detection using the alerting profiles.
Babar
Hello Babar,
The alert works fine, I appreciate all your help.
