Set up an alert on a specific host group that will kick of when a specific process IS running.
Need to set up an alert on a specific host group that will alert when a specific process IS running. Process Availability only allows for alerting when a process is not running. Anyone have any experience with setting this up?
If I understand your use case, this should be done in process group. You can check Process group availability monitoring and alerting.
Best regards
