Any tips and guides on how to setup alerts for Solaris in Remote Unix Monitoring. Specially for the monitoring of mount disks. Thanks.
Hi @AbbieA
You can create a metric event on the mounts and disks metrics that this extension collect
HTH
Yos
@AbbieA As suggested by @Yosi_Neuman is the best solution, as i have implemented the same, created metrics events as per the documentation and works perfectly.
Thanks, it works!
