Hello everyone!
I’m currently reviewing about Log Monitoring Classic that will be applied to one of our client’s DT Managed environment.
From the Log Alerting documentation and demo I can use the metric I made from the log viewer in anomaly detection and make the threshold I desired. But I can’t find the example of alert if the metric is reached the threshold.. So anyone here can help me to give the example?
Thank you for all the help and tips
Hi @bayu_irsan
Here is an example problem about a log metric (it has 8 dimensions and this problem filtered for one dimension’s anomaly):
I hope it helps.
Best regards,
Mizső
Hi, @Mizső , thank you for the help!
Can you tell me what made the alert for the error log? because I see in the graph the value is not changed during the problem time
Oh there is a small thing above the threshold. I’m sorry for my dull eyes :grin:
Thank you @Mizső , It’s totally helpful for me!
