Alerting on a process needing a restart
Hi @Yosi_Neuman ,
I tested your .py file. It ran but showed no results. Can you let me know if the results of running the tool will produce any report files?
Thank you for your help.
Hi @CuongNTM
The attached zip file was made to be load and run as  ActiveGate extension which will run the code every minute and open CUSTOM_ALERT or AVAILABILITY_EVENT which will generate a problem.
You can collect information about all the problems with Rest API to a different tool and produce a report from the pulled data.
Another way to tackle your need can be with the /monitoringstate API @Julius_Loman mentioned
HTH
Yos
Hi @Yosi_Neuman ,
Thank you for your help. I will learn more about what you mentioned. If there is a more useful tool, can you recommend it to me?
Hi @CuongNTM
Don’t think right now there is another way to do that
Yos
Has there been any out of the box development on tracking process needing restart for injection to complete? Do we still need to build a custom extension to monitor this or has there been a dynatrace app built to do just that? Thanks.
