@Chris N. So as a managed customer we had the same question and this was our solution.
Once a month we would have patch night where the entire system would be taken down and systematically rebooted. So lets say that at 10pm, on January 19th till 5am January 20th, we will be restarting devices and we dont want to be alerted on issues as we are aware of them and performing reboots.
Set your maintenance window.
As you can see in the screen shot, we have named and filled out the details for the Patch night Maintenance. We defined the time frame and now we need to select the actions of alerts.
1.) Detect Problems and Alert - In this case all baseline and SLA calculation will be suspended for the duration of the maintenance window.
2.) Detect Problems but don’t Alert - This is a viable option but has its drawbacks. The biggest issue with alerting users of issues after the maintenance window expires. Lets say Host A is the last server to reboot at patch night. Host A gets rebooted at 4;30am and has 30 mins to come up before that 5am maintenance window expiration. Lets say for some odd reason, that host does not come up, Its now 5:10am and the window has expired, Dynatrace will still list this host issue in the problems page but no alerts via email or custom integration will be generated as the problem opened up during that maintenance window when alerts were suppressed.
3.) Disable Problem Detection During Maintenance - This is what we use. Dynatrace will turn a blind eye on issues during the defined time frame. but most importantly, the system will then detect AND ALERT on any issues after the maintenance window expires. In this case, Host A would be alerted as unavailable after ‘X’ amount of time per your alert profile.
Keep in mind, I used hosts as an example but this goes for everything within Dynatrace so CPU, Memory, Disk Space, services, processes, transactions etc… Using the second option will not initiate alerts to problems that have opened up during the maintenance window, even if they remain open after the window expires.
Please let me know if you need anything.
-Chad
