Thank you for your feedback. One question about this, what happens in this scenario?
Problem is created but no alert because entity has the tag, it means, problem is ignored.
After 3 hours tag is removed because patch has finished, but something was wrong, it means, it is a real alert now.
Issue is still there but problem was created under maintance window, it means, no notification because it had been created during a maintenance window, and maintenance window still exist. How do you re-valuate problem to get notified? Some “watchdog” workflow?
re-evaluation of maintenance window is not possible afaik. You can only try to narrow patching window to be as small as possible via adding/removing tag into patching procedure, so it will trigger maintenance window only for neccessary patching time.
Re-evaluation of alert in maintenance windows is happening at the end of the maintenance window but in case the mw is infinite and based on tag, there is no end and therefore no re-evaluation.
