Alerts Limit reached, using metric selector for success percentage
In our org, the limits were reached as we are using metric selector for our alerts.
we use success rate query which is like a percentage. So any other ways we can achieve the same using metric-key, but there we cannot calculate the percentage, if we start to use seasonal baseline it will also hit limits easily as we have a greater number of teams.
builtin:service.errors.server.successCount:names:filter(in(“dt.entity.service”,entitySelector(“type(~“SERVICE~”)”))):splitBy(“dt.entity.service.name”) / (builtin:service.requestCount.server:names:filter(in(“dt.entity.service”,entitySelector(“type(~“SERVICE~”)”))):filter(series(sum,gt(50))):splitBy(“dt.entity.service.name”)) * 100
If your org has already hit the alert limits due to using metric selectors (especially for calculated success % and with a large number of teams/services), then the most pragmatic next step is to contact Dynatrace Support and open a ticket.
It’s highly likely Dynatrace can review your specific use case and adjust tenant/cluster-side settings — for example increase certain limits or recommend an alternative configuration so you don’t immediately hit limits again as you scale (seasonal baselines + high splitBy cardinality typically consumes limits very quickly).
Another alternative could be using Davis Anomaly Detector instead, if you are in SaaS. That limit is only for classic metric events.
Best regards
