alert a metric based on a dimension
Hello, I would like to know if it is possible to alert a metric occupying one of its dimensions, that is, I have a table where several dimensions come, for example the total number of transactions, failed, successful and pending transactions and I want to alert if there are failed transactions and if there are transactions by process
Hello @Jorge3229
I might not understand the desired requirement, but did you check the calculated metrics for service documentation?
https://docs.dynatrace.com/managed/shortlink/calculated-service-metric
Babar
