Alternative project to Dynatrace Operator
Hi!
The first step for Deploy Dynatrace Operator is to add a new project: oc adm new-project --node-selector=“” dynatrace
We could create this project with another name? Ex: oc adm new-project --node-selector=“” dynatrace_new
Documentation link: Deployment — Dynatrace Docs
It is not officially supported, but it should technically be possible. However, please note that you need to change the namespace mentioned everywhere in the openshift.yaml to that value as well.
Sia
