A customer asked me if there is a simple way to test/try out the installation of the Dynatrace operator for kubernetes.
What I advised him was really simple, all you need is your laptop and hope it is not to rigorously protected by your employer.
You can install docker desktop and enable kubernetes.
(please read the requirements)
When finished you could install easy travel:
see GitHub - BraydenNeale/easytravel_k8s · GitHub
Best to start cmd and do a “>docker pull” to get all the images from the manifests locally. after this you can do a “>kubernetes apply -f manifest.yaml (s)” to start the POD’s
For the order and syntactics you can have a peek at the scripts in the Github repo.
Next step could be to install the dynatrace operator :
Good luck but more important have fun!
Remarks, improvements experiences? Please feel free to comment
KR Henk
