Hi, not sure where I can raise this outside of the Q&A sessions for partners…so I’m raising the question here for debate.
There’s a question that is in the Dynatrace Platform Architecture and New Apps Quiz.
Q: Deploying a Dynatrace Operator on a Kubernetes cluster will… (Select all that apply)
- Provide Kubernetes observability
- Allow anomaly detection
- Deploy an ActiveGate on that Kubernetes cluster
- Deploy the easytravel application for demonstration purposes
- Automatically restart unhealthy application pods
However according to the Dynatrace documentation, the Operator doesn’t do any of these. 1/ K8s observability is provided by code module injection. 2/ Anomaly detection is done via Davis AI or in the Dynatrace Platform itself. 3/ ActiveGate deployment is done via a separate DynaKube deployment. 4/ EasyTravel is just a demo app done in a separate deployment. 5/ The Operator doesn’t restart regular k8s applications pods.
In every instance of the documentation, the Dynatrace Operator “manages the automated rollout, configuration, and lifecycle of Dynatrace components in your Kubernetes environment”:
- Kubernetes platform monitoring — Dynatrace Docs
- Application observability — Dynatrace Docs
- Full-stack observability — Dynatrace Docs
- Classic Full-Stack monitoring — Dynatrace Docs
- Host monitoring — Dynatrace Docs
I’m at a bit of a loss as to what’s the expected answer here.
