I’ve found it personally easiest to stand up a local K8s Cluster using Docker for Windows + Windows Subsystem for Linux (WSL). Provides a free single node K8s Cluster that can run DT Operator as needed for testing/validation: WSL+Docker: Kubernetes on the Windows Desktop | Kubernetes
There is K3s if we want a RaspberryPi based K8s Cluster.
Hi @bsnurka ! My first idea was to use Kind or even Minikube too, but I was trying to avoid them because I don’t know if EasyTrade application would work it…besides, in real situations, we run applications in full multi-nodes k8s.
Have you ever tried implement a DT Operator for monitoring them?
I’ve heard about a free tier in Oracle Cloud, where we can get up to 24 GB memory total, dividing amoung up to 4 instances…Maybe It would be possible to implement a k8s. I don’t know whether it still a valid offer.
I installed easyTrade App on EC2 instance inside minikube. It works, after some little changes, but in this shenario it is impossible for me to access to frontend. It is a service (type load balancer) inside a minikube cluster
I tried to use minikube tunnel but it should be better another solution, perhaps changing the type of frontendreverseproxy-easytrade service (no LoadBalaner) and using an Ingress
But I dont want to change easytrade deployment unknowing other side effects
