- May I know if Dynatrace support Aurora Postgresql V14 ?
- Dynatrace has all Aurora Postgresql Available Metrics ?
- My support team said Dynatrace only support on Aurora Postgresql V11 ? but we are running on V14.
- Please advise how Dynatrace ingests metrics on Aurora Postgresql ?
Hi @WenG
PostgreSQL 9.4+
Collected metrics
Active connections Number of active connections to all databases running under PostgreSQL Buffer hit Number of times disk blocks were found in buffer cache so that a read was not necessary (only includes hits in the PostgreSQL buffer cache, not the OS file system cache) Cache hits ratio Percentage of accesses that result in cache hits Block reads Number of disk blocks read in the database per second Rows returned by index scans Number of live rows fetched by index scans Rows updated Number of rows updated by queries in the database per second Rows inserted Number of rows inserted by queries in the database per second Rows deleted Number of rows deleted by queries in the database per second Rows returned by sequential scans Number of sequential scans fetched on the table per second Index scans Number of index scans initiated on the table per second Commits Number of transactions committed to the database per second Rollbacks Number of rolled-back transactions in the database per second -
I cannot confirm v14 but running versions 11+ without problems, so…
do you want to ingest metrics? please clarify.
My Id only can see chart on CPUUtilization Average (ext:cloud.aws.aurora.cpuUtilizationAverage)
My Id not able to see data for the rest above metrics. But Last written on 2023-02-23 11:15. Advise ?
I guess so, I’m running 13.7 without problems. For sure v14 is supported, at least is documented.
Thank you so much.
I am now asking my Dynatrace support team to enable the metrics.
By any chance you can share Dynatrace on Aurora v14 document link ? Thanks
Yes, it says 9.4 and above.
@DanielS Could you please help me whether Dynatrace able to monitor Aurora PostgreSQL and let me know collected what are metric it can collect. I am unable to find AWS icon on Cloud and Virtualization . Please share any documentation
Hi @karthikmv, you need to do it through the Settings Classic App. I leave the steps below.
Thank you @DanielS for reply. I am unable to find steps on note
Sorry @karthikmv , the above steps explain you how. The post with date
23 Feb 2023 01:40 PM
