Dynatrace managed offers integrations to allow leverage RDS Performance insight Data
Please advise if
1) the Dynatrace managed offers integrations to allow leverage AWS RDS Performance insight Data, to gain deeper insights into the database performance.
2) the Dynatrace managed can setup  “Monitoring on Aurora Postgres performance via the EF2.0 extension framework.”
  • monitoring top queries
  • fetching Execution plan details on PostgreSql
Hello @WenG
For PostgreSQL you can proceed with the available OOB extensions offered by Dynatrace:
Hoping it helps.
BR,
Peter
Thanks For the follow-up.
  • Yes, Dynatrace integrate with AWS Performance insight on deeper insights on db performance monitoring is what we are looking for.
  • We have Dynatrace Managed version 1.310.83, can you please advise if something we can implement for adding monitoring top queries and fatching Execution plan for PostgreSql ?
Limitations
Execution plan details:
  • Only available to SaaS users with DB App installed
  • Execution plan can only be fetched from the database where dynatrace.dynatrace_execution_plan function has been created.
Wen
Hello @WenG
Thanks for your response.
Kindly find the below helpful resources:
also ensure the OA related feature is enabled and required action is applied accurately
BR,
Thanks.
