Announcing vulnerabilities in Smartscape view
The Smartscape topology will be extended to highlight entities that are affected by vulnerabilities. This gives you access to a detailed topological view of your entire environment, focusing on application security.
For the processes and hosts layer it will be possible to switch between showing problems and vulnerabilities. The affected entities (nodes) will be colored according to the severity of the vulnerabilty. The view can be filtered by severity, this allows you to quickly get a clear overview of critical vulnerabilities in your environment.
The new functionality will be available to all customers with a subscription to Dynatrace Application Security, starting from release 246.
Awesome, thanks for Sharing @AndreaFabricius
