Anomaly Detection - MW
How to add a management zone post a DQL query in anomaly detection?
The aim is to adopt/bind the problem with the same alerting profile which use to work for metric event as there we had an option to filter management zone.
MH
Hi @munawarhossain3
Maybe I’am wrong. But check the workflow solution.
I hope it helps.
Best regards,
János
The purpose is to migrate the metric events to new anomaly detection.
