Hi Dynatrace community
We have the following case where several applications are deployed across multiple domains:
- https://acme-corp.example.com/applicationA
- https://acme-corp.example.com/applicationB
- https://acme-corp.example.com/applicationC
- https://umbrella-corp.example.com/applicationA
- https://umbrella-corp.example.com/applicationC
- https://umbrella-corp.example.com/applicationP
As you can see, multiple customers use a different combination of applications. As far as application detection rules go, we’re defining rules like the following:
URL contains “[company-name].example.com/[applicationPath]”. However we’re noticing that the actual injection is not working as expected. What’s being injected is the default app. We’re not sure why that’s happening. Any pointers or tips appreciated.
