Application Log monitoring
would like to know how dynatrace monitors Application error logs?
Hi Roshini,
You have more options:
1. Log monitoring:
You can find the relevant information in the documentation. Log Monitoring | Dynatrace Docs
When you select an application log to monitor you will have different options to “record” the errors.
- Create an event by filtering for the error pattern
- Create a log metric by filtering for the error pattern (I perfer this, I can count it, vizulaize and then create an alert). See a simple filtering rule.
2. Use the Multidimensional analysis feature for the application exceptions. You can reach it form the main menu or from the choosen service. Exception analysis | Dynatrace Docs
I hope these information help you.
Best regards, Mizső
