I’m new to Dynatrace so bare with my dumb questions here
What I need is to make Dynatrace to watch a very simple log file in text format , check for a specific value and raise an alert if found.
So far I was able to specify a custom log source under a process that produces my logs but it seems Dynatrace does not want to monitor it. Why is that?
Also , I stumbled across log processing rules and I 'm struggling to create my own to simply find a word sequence there. All examples seems related to known logs from web servers like nginx /haproxy and includes some pretty complex data manipulation. Plus, It seems that logs should be in JSON format? At least that what’s required for Rule Testing section..
I have a feeling that I’ve missing something obvious here - can you point me to the right direction how can I:
- add a text log file to Dynatrace
- add a rule to simply check for words “exit code XXX”
That looks promising, a question regarding switching to Log Monitoring v2 - what will we lose when we switch to v2? We dont monitor any logs yet , but if we do, would we need to redo all log metrics ?
Not sure how this forum works, but the first post that was “accepted as a solution” (not by me btw) did not answer my questions - it just contains links to general DT docs, which I already read before asking those questions. I will re-read them and try solutions provided by Mizsco and report back.
I think the answer yes. You will have to redo the log metrics. I was lucky because I switched to v2 quite early I did not have to much v1 configuration. You should do it as soon as possible because as you may read v1 support will end by 01.2024.
Regarding the v1 vs v2. No questions, v2 has much more possibilities than v1. I perfer it.
1. So far I created Custom Log Source configuration and I also created Log Storage configuration for the same log file - now i see my log in Logs&Events.
2. I’ve added DQL rule to filter my log data to show only “exit code XXX” lines
3. Looks like I’m good to go to create a Log event.
log.source= “/opt/oracle” AND (content=“ORA-”). This is log source. instead of searching for content, i want to search ORA- in the first line in the log only. How to do that
log.source= “/opt/oracle” AND (content=“ORA-”). This is log source. instead of searching for content, i want to search ORA- in the first line in the log only. How to do we do that?
Now alerts are generatiing if ORA- is there is any part of content, instead we want to alert generated if ORA- is present in first line.
