How to know if i am using log monitoring v1 or v2?
We are using Dynatrace SaaS platform and could see a Log monitoring on grail activation pop up in Logs page, but how could i confirm if we are using log monitoring v1 or v2 ?
If you can see the grail pop up activation you are using log v2
You can detect if you have v1 in Settings, but even if you don’t have Settings, go to the Classic host page, on the bottom right you should see:
Click on one of them, and if you see something like the following, especially the “Download log files” button, you have the oldest Log  monitoring version…
Thanks for the response AntonioSousa, But, i actually don’t see logs on hosts page (o logs) , logs are not directly ingested from the hosts but were forwarded using dynatrace-aws-s3-log-forwarder
So, you should have v2 then :blush:
v1 is only available in older tenants that didn’t switch to v2, so they should be pretty rare these days…
