Application Rule based on Regular Expression
It is possible to define an Application based on a regular expression provided? We would like to include a subset of URL to activate UEM on them only. Currently, It seems Regex is not available as choice.
Thank you,
At the moment it is not possible to use a regex.
Hi Davide,
If you want to exclude/include certain pages from UEM injection, you can also go to the advanced settings of the Application and define JavaScript injection rules.
Here you can use equals/starts with/ends with/contains on the URL, still no regex though.
Hope this helps to accomplish what you need.
What is the particular use case here? Why do you only want to enable UEM on a subset of pages? In general, I could see the need to exclude a couple of pages but not the other way around.
Hope this helps.
KR,
Kristof
