This article is about using Dynatrace AppSec and dealing with reported false-positives in your applications.<br>Looking for <span>known CVEs in Dynatrace components</span>? Go to <a href="https://cve-status.dynatrace.com" target="_blank" rel="noopener noreferrer">https://cve-status.dynatrace.com</a>
This is a Self Service Diagnostics article of type Full-Self-Service.
For unexpected product issues on the Dynatrace side please submit a Support Ticket.
Self Service Summary
| Issue | Solution | Tasks | Alternative |
| Reported third-party vulnerabilities for certain process groups or Kubernetes nodes are not relevant for your environment | Mute entities: They will be hidden and not taken into account for Application Security metrics or Davis Security Score | Mute* entities via UI (security problem or its individual items) or API (security problem or individual items) | Set up fine-grained Security-monitoring rules for affected processes, e.g. based on process or host tags |
* Available mute state changes include CONFIGURATION_NOT_AFFECTED, FALSE_POSITIVE, IGNORE, OTHER, VULNERABLE_CODE_NOT_IN_USE
The following query examples may be helpful to identify relevant processes before muting them:
Filter by Java version
This example shows how to filter out processes of a security problem with a Java version < 9.
Steps to reproduce:
- Get all security problems
- For each: Get a list of “affectedEntities” (processes)
- For each: Get entity (process) property “softwareTechnologies” and filter by version (“type”=“JAVA”)
...<br>"softwareTechnologies": [<br> {<br> "type": "JAVA"<br> },<br> {<br> "type": "JAVA",<br> "edition": "OpenJDK",<br> "version": "1.8.0_312"<br> },<br>...
Related Python script: GitHub - robinwyss/spring4shell-dynatrace-export · GitHub
Filter by third-party library data
This example shows how to identify processes with a certain third-party library package name or version.
Step to reproduce: Get entities using
- “entitySelector” type(SOFTWARE_COMPONENT), softwareComponentType(JAVA) and your specific criteria e.g. packageName(org.springframework.boot:spring-boot), softwareComponentFileName(spring-boot-1.5.12.RELEASE.jar), or softwareComponentShortName(spring-boot),
and response “fields” fromRelationships.isSoftwareComponentOfPgi to retrieve affected processes. - previously identified Process Group Instances and response “fields” fromRelationships.isInstanceOf to retrieve affected Process Groups required for remediation.
Notes:
- The libraries in use by PROCESS_GROUP_INSTANCES are reported as SOFTWARE_COMPONENT entities by the OneAgent.
- Possible properties of an entity of a specified type can be listed via the entityTypes API.
Request 1:
GET /api/v2/entities?entitySelector=type(SOFTWARE_COMPONENT),softwareComponentType(JAVA),packageName(org.springframework.boot:spring-boot)&fields=properties.packageName,properties.softwareComponentFileName,properties.softwareComponentShortName,properties.softwareComponentType,fromRelationships.isSoftwareComponentOfPgi
Response:
...<br>"entities": [<br> {<br> "entityId": "SOFTWARE_COMPONENT-x",<br> "displayName": "org.springframework.boot:spring-boot:1.5.12.RELEASE",<br> "properties": {<br> "softwareComponentFileName": "spring-boot-1.5.12.RELEASE.jar",<br> "softwareComponentType": "JAVA",<br> "softwareComponentShortName": "spring-boot",<br> "packageName": "org.springframework.boot:spring-boot"<br> },<br> "fromRelationships": {<br> "isSoftwareComponentOfPgi": [<br> {<br> "id": "PROCESS_GROUP_INSTANCE-x",<br> "type": "PROCESS_GROUP_INSTANCE"<br> },<br> {<br> "id": "PROCESS_GROUP_INSTANCE-x",<br> "type": "PROCESS_GROUP_INSTANCE"<br> }<br> ]<br> }<br> }<br>]<br>...
Request 2:
GET /api/v2/entities/PROCESS_GROUP_INSTANCE-x?fields=fromRelationships.isInstanceOf
Response:
{ <br> "entityId": "PROCESS_GROUP_INSTANCE-x", <br> "type": "PROCESS_GROUP_INSTANCE", <br> "displayName": "NAME", <br> "fromRelationships": { <br> "isInstanceOf": [ <br> { <br> "id": "PROCESS_GROUP-x", <br> "type": "PROCESS_GROUP" <br> } <br> ] <br> } <br>}
