Im taking the Dynatrace Backstage plugin into use and got confused in what OAuths do I have to use for <env>.sprint.apps.dynatracelabs.com, and does my SaaS environments map to sprint.apps.dynatracelabs, /we that is, there is no real documentation about what this sprint.apps.dynatracelabs is.
Now I get it, for some reason I had never heard of this dynatracelabs and though all the communication had to go through that API.
However: you just use the same SaaS API where the data, metrics, everything is and it works, there was even a guide in the multi-environment with the SaaS APIs.
