Databricks extension Dynatrace URL
I saw on the databricks monitoring configuration that it gave 2 examples for what you could put into the Dynatrace url.
https://{environmentid}.apps.dynatrace.com
Would that mean that the correct Dynatrace URL would be https://{environmentid}.apps.dynatrace.com?
Thanks for the assistance
Hi @danielD
I can see these two examples. Fist is the Saas, the second is the Managed format.
https://{your-environment-id}.live.dynatrace.com or https://{your-domain}/e/{your-environment-id}
I think the first could be https://{your-environment-id}.apps.dynatrace.com in case of SaaS with the new look.
Best regards,
Mizső
