VsCode extension enviornment URL error
Hey All, I am trying to add a Dynatrace Extension to my Dynatrace Managed environment. Every time I try to add the URL. I get “The environment URL is not reachable” and “Unable to verify first certificate.” Has anyone encountered this before and does any know how to help. Will I still be able to use the vscode extension to help me or will i have to soley use the cli with the flag of "--no-check-certificate " I have also attached the logs. Let me know what you all think.
Hi @trevordconsult ,
Please take a look at this GitHub issue that was recently closed that may help :
David
I am not sure this is the same thing. I am trying to add the Dynatrace Managed environment, so then I can create a python 2.0 extension. I have not even connected the environment yet.  Unless I am just not understanding. Will this work?
Hi @trevordconsult
Please correct me if I’m wrong but it looks like the error log you posted above is from the Dynatrace Extensions VSCode extension/Add-on :
If so, then the link to the comment will help you set up that VSCode Add-On to be able to connect to your Dynatrace Environment. The VSCode Add-On has it’s own configuration and you can edit the settings.json file for your VSCode installation to control them.  In VSCode if you go to File → Preferences → Settings you can search from Dynatrace and edit the json file.
If that is indeed the issue, from there you can use this VSCode Add-On to create a Dynatrace Extension (including a Python EF 2.0 one).
i am running into same issue as well
i did added tenant connectivity settings
here is my settings.json file
“https.proxyAuthorization”: true,“dynatraceExtensions.developerCertkeyLocation”: “/Users/lidsc82/Library/Application Support/Code/User/workspaceStorage/a3e208e5a62162e200a539a06a885512/DynatracePlatformExtensions.dynatrace-extensions/certificates/developer.pem”,“dynatraceExtensions.simulator.defaultMetricsIngestion”: true,“dynatraceExtensions.logging.maxFileSize”: 50,“dynatraceExtensions.simulator.defaultLocation”: “REMOTE”,“http.proxyStrictSSL”: false,“workbench.trustedDomains.promptInTrustedWorkspace”: true,“dynatraceExtensions.rootOrCaCertificateLocation”: “/Users/lidsc82/Library/Application Support/Code/User/workspaceStorage/a3e208e5a62162e200a539a06a885512/DynatracePlatformExtensions.dynatrace-extensions/certificates/ca.pem”,“settingsSync.ignoredSettings”: [“-python.pipenvPath”,“-python.venvFolders”],“pythonTestExplorer.testFramework”: “pytest”,“dynatraceExtensions.tenantConnectivitySettings”: [{“tenantUrl”: “https://dt-managed-notprod.*****.com/e/e1fc6b45-c7e7-4329-82c4-ef4b67d8a94f”,“certificatePath”:“/Users/*****/Library/Application Support/Code/User/workspaceStorage/a3e208e5a62162e200a539a06a885512/DynatracePlatformExtensions.dynatrace-extensions/certificates/ca.pem”}],“gitlens.gitCommands.skipConfirmations”: [“fetch:command”,“stash-push:command”,“switch:command”],“dynatraceExtensions.logging.level”: “DEBUG”,
settings.txt (466 Bytes)
