I want to copy a custom extension build from one tenant to another. What are the available ways to do that?
I tried using Dynatrace Extensions: Build in Visual Studio Code, but it produced the following error:
"error": [
"'dt-sdk' is not recognized as an internal or external command,",
"operable program or batch file.",
"detailedOutput": [
If you have the ZIP extension file, just upload it to the new tenant. Don’t forget to setup the certificate files, as I’m assuming it’s a custom extension of course.
I think you should familiarize yourself with Python virtual environments and how they work. A good starting point is this guide: https://realpython.com/python-virtual-environments-a-primer/. (TLDR)
Alternatively, you can ask your AI assistant to explain virtual environments and help you use them correctly. I can see that you already have one set up in your project.
