ASK: Maintenance window
How can i apply a maintenance window just for onde disk/partition in dynatrace ?
You can use Custom tags API - POST tags for adding those custom tags on the disks. But I am afraid maintenance window will ignore them or not.
You can make a test. If they are ignored, an alternative would be adding a event exception in the alerting profile to avoid problem notificacion is triggered.
Best regards
