Hello good Morning!
We have an integration with AWS services, but we do have some alerts that we’d like to disregard or put into a maintenance window. An example might be Lambdas.
Considering only the integration, we couldn’t put them in maintenance even creating a specific Tag for them.
Do you have any other solution, to disregard AWS alerts?
Thank you very much!
you can now tag almost all entities with the new entity selector. Try tagging all the entities you need, then you should be able to set a maintenance window to it. But I agree, the maintenance window section needs to include all aspects.
I recommend tossing in a RFE for future enhancements
Hi Chad
I created through the “entity selector” thinking it would work, it wasn’t possible.
Irie forward to the RFE.
Here is a Product Idea for this topic:
AWS Services Maintenance Window
If you want to see this feature in Dynatrace, vote on it and increase its visibility to our Product Managers.
