Hello, So I am trying to configure a maintenance window in DT SaaS like we used to do in DT Managed. But, the thing is that, we have configured few alerts in Davis Anomaly detection and I do not want certain alerts not be triggered during certain time in the midnight. When I am trying to configure maintenance windows in the new UI, I am unable to select the alerts from the Anomaly detection as it doesn’t appear in the options of entities.
Unfortunately, we have tried adding tags to our alerts, but still we are unable to add the maintenance windows. Is there any other way, we could pause those alerts everyday during certain time in the non-business hours.
Maintenance wiindows seem to be a classic app so a lot of the new functionality doesn’t work here.
A couple of options:
1. Create a management zone where the entities within your Anomaly detections fall. That way you can get them in a management zone and use the management zone in the maintenance window.
2. Just disable the Davis anomaly detectors (via scirpt / monaco) → a bit more work
3. If you just don’t want alerts being send over you could potentially just create an alerting profile where you filter out the alerts. Davis anomaly detectors are simply events so you can filter on them. Unfortunalty that does not reducee the number of problems.
Personally I would investigate the Management Zone route.
