Audit event: maintenance window
Hello members of this great community,
do you know if by chance when a maintenance window is set up on Dynatrace then an audit event is written into new saas Dynatrace dt.system.events?
Or if ti is written somewhere else?
Regards
Found the solution:
in DQL you need to run this query
fetch dt.system.events
| filter event.kind == “AUDIT_EVENT” and event.provider == “SETTINGS” and matchesPhrase(details.dt.settings.schema_id, “builtin:alerting.maintenance-window”)
